GR Yaris Replacement rearview mirror
Is it any smaller in height? It looks shorter width ways but longer hight wise
Has anyone come across a manually diming mirror? The mechanical type. I detest "automatic" dimming, it's never fast enough or dark enough, I consistently get dazzled. End up tilting the mirror down to avoid it.
So it seems:
Stock mirror is 270x80x70 (rounded figures but close enough)
080 and 100 are 240x70x70
0WK00 is 250x80x70
I can easily get the 0WK00... I think I will try to grab the 100 or 080 though. I am 182cm tall and sitting in the seat that 5mm each side looks useful.
Can someone with an 0WK00 actually measure it please???
There are lots of others that look the same in the photos but who knows what physical size they are.
EDIT: A search of ToyoDIY ( thanks @swistak ) shows that all three of these mirrors have been installed in the Yaris Hybrid.
080 and 100 are the same except 100 is PRE-COLLISION SYSTEM-WITH&LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME). So presumably something is different between these two apart from the part numbers yet if I recall the wiring is the same with no additional wires? 0WK00 was also fitted and seems to be a replacement for 100.
The GR does have light control if that is auto lighting but what are the other bits????????????????
@Funky that listing also shows 87810-0WQ40 as an interior mirror without any electronic bits so perhaps that is what you are after.
Thanks for the number, that looks like the one I want. None available for sensible money that I can see though, don't really want to spend £100 to get one from the US! Hopefully my local scrappy has one kicking around.
Apologies for the delay...
The Std mirror is roughly 268mm wide by 80mm tall
0wk00 is about 243mm wide & the same height
Thought I'd fit the mirror & step away from the computer for 10 mins. 20 minutes later its all on. As bergergr said previously, it's an exact fit.
10 mins to fit and another 10 to dremmel a small wedge out of top of the first knuckle joint casing, allowing it to move up another cm or two!
Aus-based as well, couldn't find 100 or 080, is it sold under a different code here? I couldn't find 87810-0WK00 either, all of them are from overseas.
any other plug and play rear view mirrors out there that's smaller and slimmer than 080 or 100? Perhaps something more modern like frameless mirror?
I am in Brissy and supposedly a few. Waiting to confirm part numbers. Punch 87810-0WK00 into toyodiy and get the details for the rav4 japan and global then ring a wrecker on the hotline and they can tell you who has a rav in bits and then call them and confirm part number. Most have limited interest in confirming... or scumtree. Having said all that I am waiting for confirmation. I suspect we didn't get 080 or 100 or it was very limited.
Just did a local search on gumtree, they're wrecking a few RAV4 but most of them are pov and mid spec so they don't have the "87810-0WK00"
One I found in Melbourne is something like $250 posted and I am waiting on a couple closer to home for $100. If they are the right part...
Might make sense to save up and get lowered seats..
I'd never pay > £50 for a rear view mirror....
