The difference isn’t massive but maybe will make a difference.
2cm shorter Only paid £23 off ebay.The difference isn’t massive but maybe will make a difference.
Thanks for the number, that looks like the one I want. None available for sensible money that I can see though, don't really want to spend £100 to get one from the US! Hopefully my local scrappy has one kicking around.that listing also shows 87810-0WQ40 as an interior mirror without any electronic bits so perhaps that is what you are after.
Thank you. Sounds like I will stalk one of these.Apologies for the delay...
The Std mirror is roughly 268mm wide by 80mm tall
0wk00 is about 243mm wide & the same height
Aus-based as well, couldn't find 100 or 080, is it sold under a different code here? I couldn't find 87810-0WK00 either, all of them are from overseas.I can easily get the 0WK00... I think I will try to grab the 100 or 080 though. I am 182cm tall and sitting in the seat that 5mm each side looks useful.
I am in Brissy and supposedly a few. Waiting to confirm part numbers. Punch 87810-0WK00 into toyodiy and get the details for the rav4 japan and global then ring a wrecker on the hotline and they can tell you who has a rav in bits and then call them and confirm part number. Most have limited interest in confirming... or scumtree. Having said all that I am waiting for confirmation. I suspect we didn't get 080 or 100 or it was very limited.Aus-based as well, couldn't find 100 or 080, is it sold under a different code here? I couldn't find 87810-0WK00 either, all of them are from overseas.
Just did a local search on gumtree, they're wrecking a few RAV4 but most of them are pov and mid spec so they don't have the "87810-0WK00"I am in Brissy and supposedly a few. Waiting to confirm part numbers. Punch 87810-0WK00 into toyodiy and get the details for the rav4 japan and global then ring a wrecker on the hotline and they can tell you who has a rav in bits and then call them and confirm part number. Most have limited interest in confirming... or scumtree. Having said all that I am waiting for confirmation. I suspect we didn't get 080 or 100 or it was very limited.
Ah so it was you, I snoozed and lost on that one!Gosh must be lucky to have landed 87810-0WK00 for a mere £23.
One I found in Melbourne is something like $250 posted and I am waiting on a couple closer to home for $100. If they are the right part...
Can you put Liz back in charge? I bought a heap of stuff when the $ was closer in value. Should have got a mirror too. Oh and to change the seat involves an inspection and paperwork and more $.Might make sense to save up and get lowered seats..
I'd never pay > £50 for a rear view mirror....
