robster
Dedicated member
Thanks for this again as mine is being serviced this week and the dealer failed to find the door setting the last 2 times I asked themUnlocking Doors: It's under the [Body Electrical] [Body Control] Sections, then using the yellow [Utility] button you can select [Unit Customising], which gives you a dropdown list wherein you can select [Driver's Door Unlock Selection] = ALL and [Select Unlock Switch] = ALL. Once changes are made click [Next] to save.
Windows from Fob: Same sections. Dropdown option [Remote Key link Power Window Setting] = from 'No Support' to Support.
Hope that helps?
