Because things don't work that way any more. Having a switched live run to anything that needs it would be extremely wasteful, heavy and prone to failure.every radio has a 12v line that tells if light is on +12v or light is off 0v. it should be possible to put that signal into an input and monitor it...there are enough inputs.
why does hardware in 2022 have less features like radios in the 90s?
There is a CAN PID for the lights for sure. The issue is, that there is no standard PID for headlights in the OBD protocol. So with the way the Canchecked display in usually connected you cannot get to that information.Because things don't work that way any more. Having a switched live run to anything that needs it would be extremely wasteful, heavy and prone to failure.
Having said that, there must be some CAN signal relating to lights or ambient light levels as the infotainment display also dims automatically. It even passes this on to connected CarPlay/AA devices afaik so those can implement dark mode on supported apps.
Is that what the little nubbin on the dash at the base of the windscreen is for maybe?
you can upgrade your product with a shiftlight :
SLM08 - Shift Light Module / Schaltblitz < Displays für Motormanagements
Der Schaltblitz ist die beste Möglichkeit,um den Fahrer über den optimalen Schaltzeitpunkt zu informieren.8 superhelle LEDs sind individuell konfigurierbar.www.canchecked.de
CANchecked universal shift light plug-in module for MFD32 / MFD28, 49
In order to reach the optimal shift point this CANchecked universal shift light is indispensablewww.turbozentrum.de
and configure it from DSS software.
View attachment 2614View attachment 2615
There is no RPM specific test mode.Hi FrakassoR
I also have the canchecked display with shift light. But I can't find the RPM test mode?? Is it in the DSS software?
Thanks and regards
Oli
It‘s explained on their homepage how to set up the gear position:Hi guys love this forum. I’m new to the Yaris and new to the forum. I have just installed the can check unit. Looks fantastic.
I’ve got most of it to work but can’t seem to get it to show gear position. I’d also love to get it to show the gazoo racing logo. I’m not lazy but there’s just not enough hours in the day. Is there anyone on this thread that can guide me through it or better still sell me an SD card with everything preloaded. Either way I’m happy to pay for the service.
www.canchecked.de
have you look on the facebook page ?
I explained the manipulation to modify the animation of the screen when it is started
And I can share files for animations and backgrounds with GR logo
Hi, thanks for all your helpful posts on this. Would it be possible to get the gr logo startup animation from you please? The wetransfer link on facebook has expiredI stopped posting on the facebook page, because some people did not understand that I was not the manufacturer and that blaming me for things directly in relation to the box was useless!
