GR Yaris Canchecked
Did you just take the CANchecked light mod it into the dash or did you make your own light?
this is the cancheked part, I just removed the plastic around the LED bars to integrate the LEDs in the toyota part
Anyone else have this flash of blue issue on the custom logo boot screen? I have reloaded all the images again.
strange,
Are all the images there ?
logo00 to logo19 ?
how have you upload files ? (SD card or with software ?)
Have you try with other pictures ? (garage animation for exemple)
strange,
logo00 to logo19 ?
Hey FrakassoR,​
Yeah, I re-uploaded via the software three times and reflashed at the end of each upload..
I will try the garage one as an over write and see if that changes things.
Hey FrakassoR,​
Let me know, or I’ll do the logo again.
There may be a file that has been "damaged". It must be an image between 08 and 13 because it is in the middle of the animation.
I did think the file might have been damaged on download. I will try the garage animation. I might also try just renaming one of the images in the low number to cover 0 to 19.
It might take me a few days as I'm doing a little more post-processing on the plastic parts.
https://we.tl/t-a3fP7qyMw5
if you want to try with an other download ;)
very strange.
In any case if everything works it is the main!
Is the manipulation visible during animation?
very strange.
The blue flash was only visible once the image was loaded into the MFD
It was visible on first load after flash (slow load)
It was also visible on normal load
Hope that helps?
I think there is a problem writing via the USB cable sometimes. Like I said mine was exactly the same, then when I copied those same files onto the SD card directly it worked fine.
Yeah, that did it. Seem to be only a DSS issue.
I also did some additional post-processing to remove some of the printing lines on the vent body. Fill, sand, paint & polish.
Pre-rework
Hi
Can anyone supply me an idiots guide to install the GR logo/ Garage Door onto my Canchecked as still struggling🙈
Thanks
Ah, I was going to say I'd put them on for you mate but yeah, don't think my laptop cable will reach!
Thanks for the offer, it was the thought that counted…👍 or less you plan doing a Calais run for Xmas🤔
