Poor ride quality, can't put power down on bumpy roads without the rear end breaking traction and snapping out of line. Compared to the Elises and Evoras I'm used to, the damping feels crude. Less comfortable and less composed on road and trackI have no experience with BC coilovers but what weak areas are you trying to improve on the GR86?
I think you are expecting too much out of the GR86. Its like comparing Lidl Bordeaux with a bottle of 1970's Margaux. Also, not sure what tyres you are running, that makes a huge difference too. Also, check tyre pressures, running at factory pressure is too high, try around 30lb hot.Poor ride quality, can't put power down on bumpy roads without the rear end breaking traction and snapping out of line. Compared to the Elises and Evoras I'm used to, the damping feels crude. Less comfortable and less composed on road and track
Thanks for the feedback! Fitted the MCA traction mod last year and that does make a small improvement. Also have a stiffer front ARB, Pedders front top mounts and (as a bit of a punt) BRZ rear spring dampers from a US ZN8 which have lower rate springs.It sounds like you'd benefit from the MCA or GKTECH rear traction arm mod, it does exactly what you're after in terms of rear stability.
BC have a good following from the likes of the drift crowd and BMWs but not so much on this chassis or it's predecessor. They aren't viewed very fondly over the US, most are told to steer clear.
That's harsh! Nothing against Lidl or Bordeaux but the GR is at least a Chilian MalbecI think you are expecting too much out of the GR86. Its like comparing Lidl Bordeaux with a bottle of 1970's Margaux. Also, not sure what tyres you are running, that makes a huge difference too. Also, check tyre pressures, running at factory pressure is too high, try around 30lb hot.
I would say a chilian is more like a Hyundai N, Toyota has made affordable sports cars for years, hence I'll stick to Lidl Bordeux!That's harsh! Nothing against Lidl or Bordeaux but the GR is at least a Chilian Malbec
I'm still on the original PS4s so will definitely be trying something else when the time comes to change. I'll have a play with tyre pressures next time I'm on track but the behaviour on smooth tracks isn't really a problem - it's more on bumpy real roads where the rear end starts losing composure too early
