GR86 BC Racing coilovers experience?
MTBMartin
Has anyone tried BC Racing coilovers, either BR or DS series (or others)?
Curious what effect they have on ride quality, composure and traction on lumpy B roads. All are weak points on the GR so looking to make some improvements.
I have no experience with BC coilovers but what weak areas are you trying to improve on the GR86?
Poor ride quality, can't put power down on bumpy roads without the rear end breaking traction and snapping out of line. Compared to the Elises and Evoras I'm used to, the damping feels crude. Less comfortable and less composed on road and track
It sounds like you'd benefit from the MCA or GKTECH rear traction arm mod, it does exactly what you're after in terms of rear stability.
BC have a good following from the likes of the drift crowd and BMWs but not so much on this chassis or it's predecessor. They aren't viewed very fondly over the US, most are told to steer clear.
I think you are expecting too much out of the GR86. Its like comparing Lidl Bordeaux with a bottle of 1970's Margaux. Also, not sure what tyres you are running, that makes a huge difference too. Also, check tyre pressures, running at factory pressure is too high, try around 30lb hot.
Thanks for the feedback! Fitted the MCA traction mod last year and that does make a small improvement. Also have a stiffer front ARB, Pedders front top mounts and (as a bit of a punt) BRZ rear spring dampers from a US ZN8 which have lower rate springs.
All have given incremental improvements. More stable on initial turn in and doesn't wash out into understeer on long corners on track as much, so on-track behaviour is pretty good.
Still looking to improve the ride and general composure though.
There are so many suspension options but I'm wary of going for any of them without either experiencing them first hand or hearing from people who actually have them fitted.
That's harsh! Nothing against Lidl or Bordeaux but the GR is at least a Chilian Malbec :LOL:
I'm still on the original PS4s so will definitely be trying something else when the time comes to change. I'll have a play with tyre pressures next time I'm on track but the behaviour on smooth tracks isn't really a problem - it's more on bumpy real roads where the rear end starts losing composure too early
I would say a chilian is more like a Hyundai N, Toyota has made affordable sports cars for years, hence I'll stick to Lidl Bordeux! :ROFLMAO:
I've only driven the GR at Bedford in anger and rear end traction has never been as issue.... but I don't expect Margaux results.
In actual fact for me, front end composure is my issue. I find the front end is just not right, whether is spring rate, or rebound. Currently running 6kg springs and will change to 7kg for next session. Hopefully this will give me what I am looking for. If not, I may drop the ARB down a notch so the front suspension doesn't have to fight the ARB as much. May give me a bit more roll but hopefully more composure.
Un-fortunately for us, the GR is light for a modern car but its no lightweight in comparison to a Lotus. Weight is always the prime concern in making a car handle well and you cant really compare the handling to a Lotus. I doubt any amount of work, will give you the composure you are looking for from the GR.
Really interesting! Front end feels fine to me - just needed more camber to dial out the understeer. Stiffer front ARB hasn't had any negative effects on the front end but has helped with stabilty on initial turn-in. Rear end has sharp vertical, longitudinal and lateral movements under power unless it's a really smooth surface. Hard to nail down what's causing it - quality of the damping feels like the main culprit. There's movement in the bushes as well but I'm not keen on poly bushes so will just have to put up with that.
I drove the Bedford GT circuit while the car was still in standard spec and on the long opening left hander after the chicane near the start of the lap it would snap sideways and go into a tankslapper even being super smooth with throttle and steering. The mods and geometry tweaks have helped but can't stop the urge to tinker!
Have you changed dampers as well or just higher rate springs on the OE dampers?
Sounds like you're running a stiffer front ARB as well? Any other mods?
For sure, the GR will never drive like a mid-engined lightweight like the Elise but just for interest, the Evora was about 100kg heavier than the GR but worked amazingly well on road and track. A bit of seller's regret there :unsure:
Mine is far from stock! My issue up front is mechanical grip. Seems the front wheels can't hold to the tarmac (spring rate or shock rebound). I'm running -4deg Camber with ARB. I went out in another gr86 on the day, and his front end grip was amazing. Right hander before start finish straight, he was entering in the 90s, I was 10mph slower. We were both running fresh set of Nankangs, so rubber wasn't the factor.
Post in thread 'Some pics of my work in progress.' https://www.gr-zoo.com/threads/some-pics-of-my-work-in-progress.4777/post-121916
Looks like you're aiming for a high g, track biased setup - is that fair to say?
I have a bad case of oil surge paranoia, so have gone in the opposite direction by using low grip tyres (very old PS4s). I'm not chasing lap times - aim is to get neutral balance (it's pretty good now), progressive breakaway at the limit (i.e. fun!) and get it more composed on bumpy roads.
How do you rate the Tein RX1s? Are they 6 & 7 kg/mm springs? Ride quality compared to stock?
Modification is an expensive rabbit-hole to go down so trying to pick mods wisely, but there's a long list!
Yes, my car is rarely driven on the road for pleasure. I started with 225/40 tyres (albeit Bridgetone Race) as I thought like you, keep it still a little loose and don't over tyre, make it fun. You can only have so much fun pushing the mechanical grip to the limit. :ROFLMAO: Hence, the direction to improve the handling/grip/composure.
As a factory car, the suspension is very good, that's why i keep saying you're expecting too much.
The RX1, I have found to be a good all rounder. (I've run coilovers on various car for the past 25yrs) Depending on how you feel, can made to be softer than OEM for road use and stiffer than OEM for track. Stock is 6kg Front and 5kg Rear. I'm installing 7kg up front to see if it improves and gives me what I am looking for... if not the RX1 will be up for sale.
