Poor ride quality, can't put power down on bumpy roads without the rear end breaking traction and snapping out of line. Compared to the Elises and Evoras I'm used to, the damping feels crude. Less comfortable and less composed on road and trackI have no experience with BC coilovers but what weak areas are you trying to improve on the GR86?
I think you are expecting too much out of the GR86. Its like comparing Lidl Bordeaux with a bottle of 1970's Margaux. Also, not sure what tyres you are running, that makes a huge difference too. Also, check tyre pressures, running at factory pressure is too high, try around 30lb hot.Poor ride quality, can't put power down on bumpy roads without the rear end breaking traction and snapping out of line. Compared to the Elises and Evoras I'm used to, the damping feels crude. Less comfortable and less composed on road and track
Thanks for the feedback! Fitted the MCA traction mod last year and that does make a small improvement. Also have a stiffer front ARB, Pedders front top mounts and (as a bit of a punt) BRZ rear spring dampers from a US ZN8 which have lower rate springs.It sounds like you'd benefit from the MCA or GKTECH rear traction arm mod, it does exactly what you're after in terms of rear stability.
BC have a good following from the likes of the drift crowd and BMWs but not so much on this chassis or it's predecessor. They aren't viewed very fondly over the US, most are told to steer clear.
That's harsh! Nothing against Lidl or Bordeaux but the GR is at least a Chilian MalbecI think you are expecting too much out of the GR86. Its like comparing Lidl Bordeaux with a bottle of 1970's Margaux. Also, not sure what tyres you are running, that makes a huge difference too. Also, check tyre pressures, running at factory pressure is too high, try around 30lb hot.
I would say a chilian is more like a Hyundai N, Toyota has made affordable sports cars for years, hence I'll stick to Lidl Bordeux!That's harsh! Nothing against Lidl or Bordeaux but the GR is at least a Chilian Malbec
I'm still on the original PS4s so will definitely be trying something else when the time comes to change. I'll have a play with tyre pressures next time I'm on track but the behaviour on smooth tracks isn't really a problem - it's more on bumpy real roads where the rear end starts losing composure too early
Really interesting! Front end feels fine to me - just needed more camber to dial out the understeer. Stiffer front ARB hasn't had any negative effects on the front end but has helped with stabilty on initial turn-in. Rear end has sharp vertical, longitudinal and lateral movements under power unless it's a really smooth surface. Hard to nail down what's causing it - quality of the damping feels like the main culprit. There's movement in the bushes as well but I'm not keen on poly bushes so will just have to put up with that.I would say a chilian is more like a Hyundai N, Toyota has made affordable sports cars for years, hence I'll stick to Lidl Bordeux!
I've only driven the GR at Bedford in anger and rear end traction has never been as issue.... but I don't expect Margaux results.
In actual fact for me, front end composure is my issue. I find the front end is just not right, whether is spring rate, or rebound. Currently running 6kg springs and will change to 7kg for next session. Hopefully this will give me what I am looking for. If not, I may drop the ARB down a notch so the front suspension doesn't have to fight the ARB as much. May give me a bit more roll but hopefully more composure.
Un-fortunately for us, the GR is light for a modern car but its no lightweight in comparison to a Lotus. Weight is always the prime concern in making a car handle well and you cant really compare the handling to a Lotus. I doubt any amount of work, will give you the composure you are looking for from the GR.
Mine is far from stock! My issue up front is mechanical grip. Seems the front wheels can't hold to the tarmac (spring rate or shock rebound). I'm running -4deg Camber with ARB. I went out in another gr86 on the day, and his front end grip was amazing. Right hander before start finish straight, he was entering in the 90s, I was 10mph slower. We were both running fresh set of Nankangs, so rubber wasn't the factor.Really interesting! Front end feels fine to me - just needed more camber to dial out the understeer. Stiffer front ARB hasn't had any negative effects on the front end but has helped with stabilty on initial turn-in. Rear end has sharp vertical, longitudinal and lateral movements under power unless it's a really smooth surface. Hard to nail down what's causing it - quality of the damping feels like the main culprit. There's movement in the bushes as well but I'm not keen on poly bushes so will just have to put up with that.
I drove the Bedford GT circuit while the car was still in standard spec and on the long opening left hander after the chicane near the start of the lap it would snap sideways and go into a tankslapper even being super smooth with throttle and steering. The mods and geometry tweaks have helped but can't stop the urge to tinker!
Have you changed dampers as well or just higher rate springs on the OE dampers?
Sounds like you're running a stiffer front ARB as well? Any other mods?
For sure, the GR will never drive like a mid-engined lightweight like the Elise but just for interest, the Evora was about 100kg heavier than the GR but worked amazingly well on road and track. A bit of seller's regret there![]()
