That is a pity.
I really liked the 30/70 setting. The car rotated more on first throttle input.
I thought we had a variable switch we could adjust it manually between 60/40 and 30/70
Can always use the syvecs AWD controller.
prefer the more fixed mk1 style although in reality it is likely changing the bias on the fly as well.
in last fridays Ouninpohja run got two occasional very much FWD bias on few corner exists that I don't like. not sure if it has something to do with heating the diff or then just random no grip moment. but we didn't drive that fast so find it strange it was heat related.
That is a pity.
It's gone. How I understand it the new track setting is made to maximise laptimes in grip driving, shuffling torque front-aft to minimise over and understeer. In the AV vid here the tester lost his drifts in that setting.
Personally I always use the 50:50 setting as I found it the most consistent. New gravel mode description is apt, for fast, competitive driving on circuits or special stages. A little more front neg camber (1 toyota bolt each side) fixed the rotation on the old one, maybe not needed on new one from the above vid so you perhaps need not worry for the new one.
It's gone. How I understand it the new track setting is made to maximise laptimes in grip driving, shuffling torque to minimise over and understeer. In the AV vid here the tester lost his drifts in that setting.
Maybe more programming is done on the software side to sent more power to the outside wheel. We will have to find out for ourselves.
From the PH ice test linked to earlier:
"The new digital instruments and larger infotainment screen have been brought together in one massive housing. It isn't what you'd call pretty - and it's hardly made from the finest plastics either - but it does angle everything towards you for a more driver-focused environment. The only real downside here is that I couldn't for the life of me find the 'developed for FIA WRC' gel sticker that featured on the old car. Shame."
I was hoping that the plastics for the new dash would at least be better quality, but doesn't look like it judging from the comment above. Also no FIA WRC badge, if that's important to some...
Only way to do that with torsens is by braking an inner wheel which is extremely difficult to make it feel natural/intuitive. Better to tune in balance with drive fore/aft and geo grip balance...
Any news on the euro spec?
Premium pack
Seat heating
Steeringwheel heating
Park sensor front rear
JBL sound system
Forged wheels like on old spec is also an option.
Is the standard car always equipped with the torsen Diffs?
I don’t need the premium pack and i don’t need the forged wheels either.
Premium pack
Seat heating
JBL sound system
I have not seen no LSD diff option so maybe it is dropped ? No option mk1 rarest of all specs?
All Euro spec cars have the circuit pack as there was little or no demand for the normal version.
I do like the improved visibility and wish the OG had the option to remove the display or have it lower in the dash (some best motoring hot version videos have the JDM version without this and it looks ideal)…
From a more minor cosmetics point of view I also like the IC spray and the fact it has a mode that says “gravel” on the dial as that’s a neat touch and is just cool for some reason to me. The kudos of the original and wrc badge is probably enough of an offset for me though in that regard.
You can do this. And you have a dashboard that is 1000 times nicer than the MK2.
The IC Spray is a cool feature... but it just doesn't help :). Had this in my Evo 8 and we tested it on the dyno. Well, only with Water it's like homeopathic medicine.
I prefer to have mechanical setup, and no electrical control. also could be bad for brakes (and extra heat) if they would be used as in VW or Ford.
I've been having internal debate with adding a water/meth injection to the car to cool CAT (temps) down hot laps but ended in conclusion does not really need one as not racing.
don't really care if miss 20hp on hot days. but would be effective (but also another system to have issues). But nowadays simpler tends to be better.
That dropped navi screen looks nice but then you loose sunglasses container. but that's a good design idea.
Note on comment "improve reliability", not actually making it fully reliable.
An Engineer could also add remark that we did not add oil sump splash guards just not to improve reliability too much for full throttle driving, our service reps need to feed their families too.
:D
proper way to add mechanical LSD (friction plate) and adjust per plates/ramps.
That’s really cool! I am going to assume it’s not reversible? Looks so much better, was that self done or a kit?
Agree on the IC, it just sounds cool so maybe I’ll get a sticker printed. I can’t imagine doing a lap of a track, finding I’ve plateaued and then realising it’s because I’d forgotten to spray the intercooler enough 😝 I’ll need lots of lessons and training before I get to that level of marginal gain. I do love the AYC thing on Evos with the gravel snow track mode etc but yep purely branding for me.
