RumbleandSway
From TRAC in Australia. Bought it direct in August - 10 days from order to delivery - then had to wait till the car arrived. [[October]]
Mine is working perfectly.I'm a little confused, lots of cases where the trac module worked on this thread, and just one where it doesn't open on keyless but otherwise fine.
They're now refusing to sell any to the UK as above, and I queried if it could be install error but that isn't possible due to the connectors. So 2 out of the 25 sales not working , do we know who they are? [emoji848]
I'd like to just take the risk but not sure they're going to allow it, but I'm not sure where they'd go from here to fix it? Easier for them to just stop any orders to the UK indefinitely and focus on other countries perhaps
Sent from my Pixel 8 Pro using Tapatalk
Same as, having enquired myself.I'm a little confused, lots of cases where the trac module worked on this thread, and just one where it doesn't open on keyless but otherwise fine.
If the Trac module hadn't worked I would have done this. I think it will work it just needs done pins swappedI still got the AliX module, when I get back to the UK in mid Nov, I'm going to get a meter onto it and try and figure out what the output wires do. It defnitely is working as the unit clicks on and off for the window closure. I think the pin-outs are wrong and nothing more.
The window closure can be changed with software configuration so you don't need to pay extra for that.I actually asked them if the 2 cars that didn't work were proper EU Spec cars or JDM imports. However, they didn't reply.
All I want is the mirror fold function, the window closure I don't actually want, as it's nice to be able to leave the windows open.
I think I'm the other one. Standard UK car, went through testing which pins had signal on lock and unlock, swapped the pins around (under guidance from TRAC), just didn't work. They are convinced the box wasn't the issue, so we called it a day. I've asked that they keep me in the loop if they get it working.I actually asked them if the 2 cars that didn't work were proper EU Spec cars or JDM imports. However, they didn't reply.
AliX ones doesn't work, I have one. They even sent me a different loom as the original loom didn't have the same wires as on the car.Guys, is it a safe bet to order one via AliX, or are these ones having issues? I am guessing they are all made from the same place anyhoo, just a different sticker on them.
Can you send pics of the loom, so I can compare the wire positions to the AliX one I got.I think I'm the other one. Standard UK car, went through testing which pins had signal on lock and unlock, swapped the pins around (under guidance from TRAC), just didn't work. They are convinced the box wasn't the issue, so we called it a day. I've asked that they keep me in the loop if they get it working.
No problem, there will be a delay as I'm in the US at the moment, back mid Nov.Can you send pics of the loom, so I can compare the wire positions to the AliX one I got.
Did it work at all or just a dud? All the AliX one done was click a couple of times, which to me meant the unit was supplying power to do the window closure.
thats good timing, I'm away from UK till mid Nov too!No problem, there will be a delay as I'm in the US at the moment, back mid Nov.
I also tried the AliX one, which also didn't work.
The TRAC one didn't do anything. The pass through worked, ie the doors locked, windows worked and the mirrors folded all on the buttons, just nothing from the remote.
I was up for trying a replacement box, but the guy seemed a little offended me suggesting it might be that.
Disappointed doesn't cover it, but I did get the hang of door cards on and off.
That's interesting alrightOn a separate note, I went to the Toyota dealership in Santa Barbara, they use a toyota app for locking and unlocking the cars as well as getting usage data.
I've asked TGB to comment...
