- Thread starter
- #281
Oh Dear, not again,
Mod list? Says 300hp and milltek catback. Anything else?
50k km and tracked.
Oh Dear, not again,
Didn't see a Mod list. All I got was - translated ,Mod list? Says 300hp and milltek catback. Anything else?
50k km and tracked.
The mods are listed in his YouTube profileDidn't see a Mod list. All I got was - translated ,
"The engine broke, damage first cylinder locks engine explode! Lifespan 50,000 kilometres Not bad for a 3-cylinder engine...Oil temperature at the time of the break, 120 degrees, according to the Carline (Boisset SA) Martigny garage, from where the car was always followed!This happened when shifting between 3rd and 4th gear.Obviously, there is no warranty coverage in view of use that is not appropriate to the Toyota Swiss warranty conditions..."
Yeah but you don't get 300hp from a milltek catback only....The mods are listed in his YouTube profile
tru datYeah but you don't get 300hp from a milltek catback only....
Depends on the dynoYeah but you don't get 300hp from a milltek catback only....
“What mods do you have, mate?”Depends on the dyno![]()
The more I read the more I’m tempted, for know to stay on stock map, especially using the car on track every now and then. I can see on that video that albeit with an airtec oil cooler, oil temp is still 125 degrees…I was hoping a much lower oil temp after fitting a dedicated oil cooler radiator.This data point is interesting in the sense that it wasn't monster power, but use was intense with good mileage. With the years and quite a lot of tracking, we will learn what works and what not long term.
There is a portugese ring rat and he's running HJS, oil cooler and IC and nothing else for power. Seems quite wise, wonder what the other regular GRY are doing.
Are you using their 'standard' cooler or the stage 3 version? I ask because their instructions for the standard oil cooler suggest mounting it with hoses attached at the bottom, which could potentially trap air inside the cooler, making it less effective.The more I read the more I’m tempted, for know to stay on stock map, especially using the car on track every now and then. I can see on that video that albeit with an airtec oil cooler, oil temp is still 125 degrees…I was hoping a much lower oil temp after fitting a dedicated oil cooler radiato
I was referring to the video posted before…not sure which one he uses but my guess is the standard…Are you using their 'standard' cooler or the stage 3 version? I ask because their instructions for the standard oil cooler suggest mounting it with hoses attached at the bottom, which could potentially trap air inside the cooler, making it less effective.
Very cool! 1.0 3-pot - a GRY avant la lettre and yours had more or less the same power to weight *and* specific output too as the DTE one above! Just no rear driven axle and a tiny bit less crash protectionReminds me of the good old days 20 years ago when I had my Charade GTti.
They were 100hp standard and mine made 180hp on the stock bottom end running 2.1 bar through a hybrid and worked head, 9000rpm limit with an ECU!
Oh, I completely missed what you had in mind, thought you were referring to your own car.I was referring to the video posted before…not sure which one he uses but my guess is the standard…
Remember what torque it had?
Oh Dear, not again,
Given car is marketed as a rally car in videos, find it a bit funny that manufacturer declines all warranty even if car is maintained as required or even above. but as said, there might be variations per country how these are handled.Quite a few have posted here since this dropped. Here's my take...FWIW.
Looking at his videos, the car is three years old, so pretty much a first-run.
While "only" 50,000km, he has beaten this car on high-speed, extended-loading circuit for its entire existence, and good on him for it.
Someone in a comment on his latest video asks if it's modded and he answers, "more or less" which to me says yes...
Watching some of his other videos, this car is quick. This car's third gear acceleration off of high-speed corners is legit, and the car holds its own on straights with what looks like a 991 GT3, and a 992GT3 RS isn't completely destroying him. At a minimum, it's got boost and a piggy-back.
He doesn't seem to upset that Toyota won't warranty it. Even here in Japan where many, many customers bought it for rally, gymkhana, etc., Toyota states that if you track the car, you own it.
