sixtentouge
- Aug 28, 2023
- 206
- 832
They were turning it 9,000 rpm7000 rpm x 8/60 s/min x 8 = ~7500 cycle metal fatique cycle, where lower loads would extend that to many millions...
That's high but a good way to make power. Some more cycles then, for the load on the rod it's bit the same, either power from cylinder pressure or from rpm still is an incredible load... the amount of fuel (E85?) should be pretty amazing too...They were turning it 9,000 rpm![]()
Good Q.A question from a non-tec guy who is interested in long term durability and is following this thread closely:
Apart from a HJS DP and exhaust the car is - and will stay- stock. What impact would an upgrade to the Kelford valve springs and camshaft have on the on drivability and power - without touching the software?
Hi there, if you’re not doing ECU software (more boost, more power and maybe raised rpm limit) is pointless to do valve springs and camshaft, and I would add it’s probably detrimental to engine life (anything you do on this car, by someone else, you risk doing it below factory standards, and that’s a big risk for me) and a waste of money.A question from a non-tec guy who is interested in long term durability and is following this thread closely:
But it's pretty well established there is? If not, tuners could just run 2 bar at 7000rpm and not need to change the springs...I see no link between valve float and increasing boost.
This is the way I look at it. Increasing boost pressure increases cylinder pressure and the engine makes more torque. More twisting force on the crankshaft. Out of interest peek cylinder pressure occurs 15-20 degrees after TDC. Maximum twisting force on the crank shaft occurs just before 90 degrees after TDC which make sense if you have ever ridden a bicycle. Increasing boost pressure by lets say 20 percent does not increase peek cylinder pressure by 20 percent. The reason we can increase the OEM boost pressure by a large amount and the engine survives (generally).But it's pretty well established there is? If not, tuners could just run 2 bar at 7000rpm and not need to change the springs...
Having difficulty imagining how the physics work is another thing, I imagine it is simply the increased amount of exhaust stroke gas that simply doesn't have enough time to evacuate the cylinder above ~6500rpm, keeping the valve open together with the sheer inertia from the valve weight, both working against the valve spring.
What I don't fully get is at what boost this happens, to me it should vary depending on the backpressure and thus what kind of mods one has exhaust + turbo side, as that clearly should influence how easy said exhaust gasses can evacuate the cylinder...
Minus the valve stem, the stock exhaust valve has an area of roughly 1.21 square inches.Considering the area of the exhaust valve and this excludes the diameter of the stem I just do not see enough increase in force to cause a problem.
I've been following this with interest as I've just installed cams and springs (EZP) on the stock ecu and I'm looking at a hybrid turbo solution for later on...On an efficient race engine, I look for absolutely no higher than a 1.5 PR. Using teh stock exhaust housing and just putting bigger wheels in it can send the PR to the moon. I've been building engines professionally since the 1990s. SAE member...yadda-yadda.
The Kelford standard springs are 87lb. on the seat, and I assume the stock springs are quite a bit less. While boost won't affect separation over the nose of the cam, it will certainly affect valve bounce on the seat when closing (float).
Exhaust pressure on the valve is an issue in turbo engines. With bucket followers, it's just a loss in power. With non-shaft-mounted followers, it can have disastrous effects, as the follower can "jump" off the valve or pivot. Any kind of misfire that lights in the exhaust (like when "tuning") and it's game over.
Not sure if something is lost in translation, but this makes no sense to me, as usually pressure ratio has nothing to do with the exhaust side, only the compressor side. Even if it did, I don't understand where the 18psi comes from as 0,5 bar x 2 = 1 bar = 14psi.Logging the stock boost curve, it seems to mostly go to around 1.7 bar by 4,000 rpm and then the ECU pulls it back to about 1.2 bar by 7,000 rpm. Changing the target to maintain 1.7 out to 7,000 rpm will (just rough calculations) decrease valve seat pressure by 18psi if we assume a 2:1 turbo pressure ratio.
Not all hybrids created equal. Unfortunately not so easy to get good information. A good one has an uprated ball bearing shaft and larger compressor and turbine (some leave the turbine stock - cheap) that both allow for more flow but at the same time don't sacrifice spool too much. Also efficiency plays a big role and can't be seen from the sizes of the wheels. Basically need to be able compare torque curves on like for like tunes, not easy.I've been following this with interest as I've just installed cams and springs (EZP) on the stock ecu and I'm looking at a hybrid turbo solution for later on...
The reason I want one is because it's plug and play, compatible with the oem ecu, can offer a reasonable bump in power (400bhp total) and the turbo won't have to work so hard to my exhaust and more importantly intake temps will reduce which is a problem I'm hitting at the moment with the oem turbo having to work so hard on track. I appreciate they may be not a perfect ultimate solution but do you think they're garbage for all applications?
Out of interest who did your tune on the OEM ECU?.Well mine will get a tune the 29th Feb, so I'll know what the score is then with additional power etc.
Car already has an OEM ecu tune and intake and exhaust mods.
Torque Performance here in Auckland.Out of interest who did your tune on the OEM ECU?.
Cheers. I don't know of anyone in Australia tuning the OEM ECU at the present time.Torque Performance here in Auckland.
