sixtentouge
Committed member
- Aug 28, 2023
- 82
- 336
- 53
Not sure if something is lost in translation, but this makes no sense to me, as usually pressure ratio has nothing to do with the exhaust side, only the compressor side. Even if it did, I don't understand where the 18psi comes from as 0,5 bar x 2 = 1 bar = 14psi.
I believe I said "psi," but meant pounds... Like 18 pounds pushing the valve off the seat. Sorry for the confusion.
There are many pressure ratios. Compressor PR, turbine PR, or engine PR, which is intake to exhaust. If we're boosting 1.7 bar intake pressure, and assuming an engine pressure ratio of 2:1, because the factory turbine is small and requires twice the drive pressure, that means 3.4 bar EP at 7,000 rpm. 1.7 bar at 7,000 rpm is .5 bar higher than stock. You are correct that that is a 14.5 psi increase. 14.5 psi on a 1.21 square inch valve area is almost 18 pounds.
Hope that makes more sense.
Normally, we get the engine through peak torque, and then pile in the boost to maintain that torque number as the rpm climbs and VE falls. Toyota's strategy on this engine is to retard the boost as the rpm climbs. I haven't measured exhaust pressure for the G16E, and likely never will, but it's a safe bet that this strategy is to keep the EPR (engine pressure ratio) in check. I'll bet it skyrockets as the rpm climbs. At 1.7 bar at 7,000 rpm, I'd put money on it nearing 3:1.
