So his conclusion is that MK2 cars have zero engine issues simply because, based on the limited releases so far, no one has reported any—yet. That’s laughable logic.
Good article but, other than reference to an intercooler, I'm surprised there's not more content relating to heat management, oil cooler, vents etcold thread but good discussion earlier so updating with good article from Whifbitz
Toyota GR Yaris Tuning Guide
The Gen 1 Toyota GR Yaris comes with 256bhp from the factory and you can give it an easy power boost with just a few mods. Now our dyno reads the power at thewww.garagewhifbitz.co.uk
Maybe it is how you use the car. On track or 30min autobahn blast its evident you benefit from improved cooling.Good article but, other than reference to an intercooler, I'm surprised there's not more content relating to heat management, oil cooler, vents etc
Yes. Tegiwa I think got 13-15bhp from it.Hm, are those claims about the eventuri intake backed ?
If yes, this intake + HJS downpipe already give you close to 290hp from the 261 stock ...
Not sure you can simply add them upp, but both relieve the work of the turbo by improving the compressor (intake) and turbine (cat) pressure ratios, hence reducing turbo work, opening the wastegate more and reducing backpressure, making more power without changing anything else (boost, fuel or timing).Hm, are those claims about the eventuri intake backed ?
