Michael Knight
thisWhat exactly do you mean with the stud in the shadow pic ?
would be great, if you can test it!
Rally1 GR Yaris is not the same car as our GR Yaris. It looks like it, but it is totally different construction. Maybe if you drive ours without windscreen it can blow off the rear window but I could bet 10€ that roof stays where it is..Well researched Mixemaxe. When doing my research I did not find that pdf and secretly
Opened every leg box I could find for Thule and several other brands ! Including a dedicated Roof bar specialist shop who were not impressed and told me if it was not manufacturer approved I was being naughty !! The Carbon roof is not designed for any weight bearing and under the
Plastic by the lip of the roof is not secure . The strength of the side roof curve is where the bar foot needs to be . The clamping force of the Thule is excellent and as I stated when installed with my 80 kg I was unable get any bar movement . The foot rubbers mould to the curve without any mods . Having seen the roof fly off in the rally ( Lappi?) it is there to keep the rain out and does not appear to offer a great deal of structural rigidity unlike the windscreen. The comments about the aero are interesting but unless you have a roof box or surf boards I think my ladders and hardware trips are quite OK . As I said before if you want a truck buy one !
Thought about something like this
These soft roof racks are quite useful but I only saw them on 4 door cars. You have to pull the straps under the roof. So I guess no way to use them on a GRY.
so the soft roof racks would not be an option !
Thanks Lanman, I just entered the part numbers consecutively into the Thule search ;-)Well researched Mixemaxe. When doing my research I did not find that pdf and secretly
fits well - what leg set did you use?
A combination of Mazda CX5 and Toyota C-HRfits well - what leg set did you use?
I am also not happy for 100% but i sits very well ;-)I wouldn’t be too happy with the front feet myself…
Looks good! Can you share the part numbers?A combination of Mazda CX5 and Toyota C-HR
