How many times do we have to cover this, it's impossible to code!Just want to say, being able to roll the windows up/down from the fob is a fantastic feature in this weather.
Best thing about the car, you can keep your lightweight, RWD, manual gearbox, fun car stuff - I'm having fun nonchalantly rolling my windows down as I walk toward the car so my air con isn't having to work as hard straight away![]()
OBD plugs don't normally latch in, just pull to remove.Just managed to connect the cable to the OBD port, went through a few settings but thought i had best check the screenshots provided before i actually make any changes.. my question is.. how do you disconnect the ODB cable once finished,, i just cant get it to come out.. just yank at it? on my Fiesta you have to push the side to get it out but on this a can't get my fingers in the gap to feel the side to see if this is the same.. i should have checked before i connected.. TIA.
Did you get a pic of the clip? Does it latch into the bottom of the plug as there is a square cut-out there? I’ve just got mine through the mail and am busy installing on my new laptop …So I managed it, it was a pain in the arse tho. There is a clip but it’s on the door side and almost impossible to see/ get to. I had to remove the side plastic panel, then pull out the plastic dash so I could get to the clip.
I’ll try and get a pic so others are aware
i havnt but i can later. So imagine its in the car like the image and the shorter side is facing the door.. the obd 'clip' gets stuck in the hole shown, well for me anyway and there's no way i can unclip it without using a screwdriver.Did you get a pic of the clip? Does it latch into the bottom of the plug as there is a square cut-out there? I’ve just got mine through the mail and am busy installing on my new laptop …
Neither of my OBD tools have a cutout like that, so there's no chance they will latch.i havnt but i can later. So imagine its in the car like the image and the shorter side is facing the door.. the obd 'clip' gets stuck in the hole shown, well for me anyway and there's no way i can unclip it without using a screwdriver.
Difficult to explain without a proper pic.
View attachment 18469View attachment 18470
that was my plan aswell.. just unsure if it would stay connected without holding itNeither of my OBD tools have a cutout like that, so there's no chance they will latch.
I'd be tempted to just snip out the front piece like on this Delphi brand connector:
Took about a day for me.. i emailed the work email address initially but i wouldn't bother as it wasn't working for him at the time so i went through ebay instead.Yeah, I was gonna snip the front off. Still waiting for a response from the eBay seller wrt my Registration Key. Software is useless without it …
Crikey, what a PITA! I've already snipped that centre piece out and filed the edges to (hopefully) avoid this issue.Had to use a flat screwdriver to leaver the top part away and then it unclips.
What option did you select on AliExpress? I ordered what I thought was the correct cable and got something completely different, and no software!I bought Techstream from AliExpress, it came with a cd that has v18, they can also send a link to download. Just tested it by changing the locking on the doors, all worked fine, if you are happy to wait 3 or so weeks for it to arrive.
mini vci V18.00.008 TIS Techstream For Toyota minivci FTDI For J2534 Auto Scanner Tool OBD 2 OBD2 Car Diagnostics cable
Mini VCI for Toyota J2534 OBD2 Diagnostic Cable
Smarter Shopping, Better Living! Aliexpress.coma.aliexpress.com
This is the one I ordered.What option did you select on AliExpress? I ordered what I thought was the correct cable and got something completely different, and no software!
Does this look right?
