Interested mate,I’m a Canchecked virgin and I’m struggling to set the thing up let alone add thisI stole a second of Top Gear montage and added GR Yaris logo animation in case anyone wants. But can't upload images here cos site doesn't support BMPs.
Hi, thanks for all your helpful posts on this. Would it be possible to get the gr logo startup animation from you please? The wetransfer link on facebook has expired![]()
you can upgrade your product with a shiftlight :
SLM08 - Shift Light Module / Schaltblitz < Displays für Motormanagements
Der Schaltblitz ist die beste Möglichkeit,um den Fahrer über den optimalen Schaltzeitpunkt zu informieren.8 superhelle LEDs sind individuell konfigurierbar.www.canchecked.de
CANchecked universal shift light plug-in module for MFD32 / MFD28, 49
In order to reach the optimal shift point this CANchecked universal shift light is indispensablewww.turbozentrum.de
and configure it from DSS software.
View attachment 2614View attachment 2615
thanks, happy to test too!Yes, I have the issue with few frames of the animation, my guess is 24bit pictures. But didn't have time to try re-uploading same 16bit ones to test out. Maybe tomorrow, will let you know.
Yes, correct. I find popping mine out to be really easy. Side off the dash, then just push the vent/gauge from the back. It was a while ago that I did it but I think that you don't need to remove anything else to access the sd cardDid I understand correctly:
- you've taken out the SD card from CANchecked
- copied files to SD card
- returned the card into CANchecked
Would like to keep CANchecked in, CBA sticking it in again![]()
