I probably have the download file as well. I cannot check today as its on a laptop which I don't have at the moment (I am away from home). I will check in a day or two and let you know.the file is no longer live to donwload, would you have it saved on your pc? Where are you mounting the sub? I was considering one too but only if it would fit under the seat which it doesnt....
I have this Pioneer sub installed in the passenger footwell. Its never going to produce alot of sound, but it rounds out the sound nicely. I was attracted to it because it can be wired to the fuse box rather the battery (done that on a previous car) and it doesn't pull too much power. When I fitted it, I was having flat'ish battery troubles, now seems to be fixed though. See this post for a installed picture. I have straighted it up now as well.
GR86 - Focal 2 way component OEM retrofit
Mounted a sub-woofer today. It's in the passenger footwell secured to the kick plate. Two bolts, with big washers on them, fed through from the back, a hole in the kick plate and carpet, allowed me to attach it where it is almost hidden from sight and doesn't bother a passenger too much. The...
