I've just fitted the Trac module. Works almost perfectly. Finally, the most annoying aspect of the car is sorted
Installation pretty easy and almost self-explanatory. The only issue I had was after fitting, as I opened and closed the door, I could hear something scraping on the back of the door card. It might have been the fuse holder they have on their loom. Not hard to fix, I just had to take the door card off again and secure the wires better, and wrap some trim tape around the fuse holder. All good now.
I say works "almost perfectly" because there is one drawback I've found (would appreciate it if other users double check this to confirm it's not fault with mine) - the module will override the manual switch in the car if it's been left in the folded position. So if you fold the mirrors using the switch, get out, lock the car, and then unlock - the mirrors will unfold even though the switch inside is still depressed.
In reality, it's not a major issue for me, the only time I would manually fold the mirrors now is when driving. But it might be worth considering if you need to keep the mirrors folded before moving off for whatever reason (perhaps if you fold the mirrors to park in a tight garage or something).
