GR Yaris I Broke my third Transmission at track 。this time GRMN close gear set
Some more HRC gear data I found
The source test Race Dog gear And average gear
This show Gr Yaris transmission part definitely very soft
Compare to the data I found
Look like
None shot penning Part ( stock GR Yaris )
Surface is pretty uneven, this might cause part to develop hair line crack at race
Have you heard anything about an Undated 1st/2nd shift gear fork when you have been doing all the research for this repair?.
If user power shift a lot or bad at shift
Will brake the shift fork plastic insert
This will cause lot wear on ur transmission
Some Japanese tuning shop developep this for their Evora customer ( same transmission like Gr Yaris)
Just found out some shop in Europe
Carry same style part , I think u could just upgrade
The bushing
Hi
I've not experienced this before.. but I'm having issues downshifting from 5th to 4th, locks up. I've got to work around it by shifting to 3rd then to 4th.
When the car is stationary no issues up+down shifting, smooth.
Also issues from 2nd to 3rd, it can grind if driven aggressively. But after a while it warms up then no issues.
Will get the mech to bleed the clutch tomorrow and find out. Would be great if peeps here can share info to check if the gearbox is damaged. Thanks
Hi
I think issue could be shift fork pad
This happend to my friend on his Gr Yaris
Japanese drivetrain specialist Cusco
Is making reinforcement gear hub too
I've ordered this, according to the supplier in JP :
They make these parts for orders only. if you order now it will be delivered end of October this year. They only have 5 sets for next lot if that lot finish then it will be next year.
Guess you'll have to watch this space around November for any updates.
Wow
Good thing u get it first lot
This arrive ~
Shift fork brass pad
I just final out I have big event at end of OCT
Now is busy time for shop
ordered a set of those too.
I'm checking with a friend who has access to proper facilities (laser cutting and 3d modeling of the parts) to see if these could be replicated at a lower cost here in Europe (seeing as the ones sold in the US are prohibitively expensive, given what they are).
Depending on pricing, of course, would anyone be interested in doing a group batch of these (12 per car - 4 per each shift fork)? Asking, so we can see if it's something that makes sense to invest time in.
Exactly same type failure like I have
This one from Japan , they are brake from edge of transmission hub
