I thought that the problem with lower octane fuel was that it would ignite itself when too hot (ie, run a performance engine hard, the fuel gets really hot when compressed, and it self-ignites before it's supposed to) - is that not right? Pulling the timing means lighting (with the spark plugs) the fuel later doesn't it? So I must have misunderstood something along the way.pulls the timing back and hence "less" torque due to earlier on set of engine "knock"....modern engines will run right up to & on to the knock limit to get the most out of the demand for full "power" hence the requirement for higher octane fuel...if your not on it you will probably never notice
