Bat out of Hell
My knob came loose as I was dropping down a gear to overtake, has anyone else experienced this ? or is it my age
See your GP.Yep my knob is easy to screw off too.
Perhaps that is how it was designed.See your GP.
Are YOU the inspiration for that King Missile song??? I won't tell anyone. Honest.Perhaps that is how it was designed.
W
Are YOU the inspiration for that King Missile song??? I won't tell anyone. Honest.![]()
Managed to get my collision avoidance to fail - warning on dash - it happened as I enthusiastically took a left turn past a car waiting to exit the junction (plenty of room) cleared next time I restarted.
Tony
Did you supply the oil ?. Mines in for the same service next month, did everything go okHad its 6k mile service done by Toyota Cardiff.
I didn't supply the oil but confirmed with them that they would be using the correct grade. This was verified when they showed me the oil to be used that was printed on the job sheet.Did you supply the oil ?. Mines in for the same service next month, did everything go ok
Two years and 15k miles in and I still have the plastic covers on the sill scuff plates (not to mention the accelerator pedal and drivers door card).I didn't supply the oil but confirmed with them that they would be using the correct grade. This was verified when they showed me the oil to be used that was printed on the job sheet.
Everything went ok, but I asked if they would look to replace the sill scuff plates as they are starting to corrode, and they forgot to do it!
Sill scuff plates. I had to Google that. Thought you meant the silicone wrc plate ...Two years and 15k miles in and I still have the plastic covers on the sill scuff plates (not to mention the accelerator pedal and drivers door card).![]()
Same.Two years and 15k miles in and I still have the plastic covers on the sill scuff plates (not to mention the accelerator pedal and drivers door card).![]()
Driving South is mint...let gravity take hold with the car in neutral and MPG bouncing around 99.9. On this, driving in reverse also helps reduce mileage on the ODO. True FACT. If you perfect this then tyre tread increases, too. Depreciation busting.Got 38mpg without really trying too hard on the way back from Leeds (hour and a half on the M1, going south, so obviously downhill).
Then got 20mpg on the B664.
What a car.
