TheManWithTheStick
Not sure where to start with this. Are any of you guys with Kelford A cams getting misfires at low RPM?
My car had final map with Litchfield at end of Oct. It wasn't the greatest experience if I'm honest but that's a story for another time.
The car has been running great but I recently changed my Ecutek dashboard to highlight low temperature things as blue until warmed and some things as red, such as high/low oil pressure and misfires > 0
To my surprise I started noticing a good few misfires! (Which sneakily seem to reset back to 0 after a few seconds, must be why I've never noticed before). But maybe this was always happening and I just never noticed.
I did notice that the misfires mainly happen at low revs - I'll see the odd one or two when driving normally but 0 when giving it full beans! Pulling in to my drive I'd see double digits of them!
I've found that just lifting the clutch in 1st or reverse and allowing the revs to rise to bite point is what causes it. I.e. when the idle goes a bit lumpy, which seems to be the norm with these cams?
I spoke to Litchfield who said to change plugs or coil packs. So I did both last week - no change, still misfiring at low load. So that was a waste of money. They then said to flash stock ROM and see if they still happen. I've just done that and moved around my drive for a few mins which did cause 1 misfire but took some doing. I then flashed my proper map back and there were 8 misfires just pulling out of my garage!
So I'm not sure what to do from here. Maybe someone with a similar setup could check if they're getting the same when manoeuvring slowly, like around a car park or something?
