SiCaln
Sorry to further intrude, with mine I have done a few things to get it all working together in the UK (GT86)JDM Talking Points
- No TPMS! It's an option and in Japan people tend not to select it because their roads are so smooth. I could find no way of retro-installing it so I installed my own TPMS Bluetooth sensors (from AliExpress) tied to a programmable alarm module and an app on my phone.
- No charcoal filter in the airbox and (unverified) no GPF filter in the exhaust.
- No head unit as standard! Many JDM cars come with no head unit, so make sure to check if you're looking to import a vehicle. Mine came with an Alpine 7DNXF2 which is Japanese-only, not configurable to another language and cannot change the time zone. Get ready to do a lot of Google Lens translation with your phone if you get a similar Japanese-only head unit. The good news (with mine, at least) is that it supports Android Auto (and Apple Car Play if you're on the dark side). That means, since your phone is driving the display, you can run Waze or Google Maps for navigation, and BBC Sounds, Radio Paradise etc. for radio and Spotify/Qobuz etc. for streamed music.
- The indicator stalk is on the right! In fact, these two stalks are reversed with wipers on the left. It takes reprogramming your muscle memory.
- Units in metric only. Your importer will have fitted a MPH speedo display, but bear in mind the dash is all-metric with fuel economy displayed in l/km.
- Small changes to the heater/aircon controls with a Sync button, but easy enough to get to grips with.
- User manual is in Japanese but I downloaded the universal English manual which has some variations for USDM, UKDM and AUSDM cars.
- All the interior lights are horrible light bulbs. Don't know if UK/EU cars are different? I bought an LED kit and replaced them all, including the external reversing lights.
- If you find a JDM car with STi aero (or GR/TRD aero), grab it as the cost is hardly any different, but the cost of importing the pieces from Japan is astronomical (I know because I had an STi front splitter on my old 2017 BRZ).
- Ditto if you find a car with STi v-bars & rear draw stiffener installed. It's commonly specified on Japanese cars. I was very lucky with the Fujitsubo exhaust, it's an option on the Subaru option list but not sure how prevalent that one is.
- If you buy a car with only one key fob (I did buy it knowing it had only one), be aware that getting another one is beyond a PITA. They are pre-coded and only available from Subaru Japan. I am now trying to get one through Subaru UK. It's not going to be cheap.
- If you are buying a BRZ (not a GR86), beware that you will need BRZ specific Brembo brakes if you intend installing them. This is because of the aluminium suspension knuckle. FastWRX in the USA was the only place I found stocking the correct calipers in kits. The kit is complete and everything goes on well. Also make sure you add the rear brake dust shields for the larger rotors, the advice to bend the existing ones could result in nasty rubbing noises if you're not very careful.
I had to wire ina rear fog as the JDM model didn't have one
I swapped to UK clocks and had them calibrated to the correct mileage
I have added headlight washers (that was more of a just in case)
I swapped out the rear facing light in the door to red
As mine is a special edition, I didn't wanna push it.
This is my journey so far if you are interested
Garage eightSix
Come on my journey in getting my Toyota 86 TRD 14R road-legal and a little bit modified. The car is a Japan-only TRD 14R, a TRD modified Complete Car Toyota 86 a road going version of the TRD 14R60 track car, modelled on the TRD Griffon that lapped Tsukuba in 0:58:407 with only aero and...
