KobayashiMaru86
I've ordered Cusco solid ones since the damped ones won't fit. Interested to see how those are.
Appreciate you sharing this insight - any other discernible benefits?Just updating this thread. I installed the GR performance damper and door stabilisers on my car today. I can confirm they do absolutely nothing for the front end resonance.
Do they have any other benefits? I gather they were meant to keep the car stiff but allow it to at least soak up bumps a bit better.Just updating this thread. I installed the GR performance damper and door stabilisers on my car today. I can confirm they do absolutely nothing for the front end resonance.
I'm really surprised by this! Logically would've thought they would solve it straight away.Just updating this thread. I installed the GR performance damper and door stabilisers on my car today. I can confirm they do absolutely nothing for the front end resonance.
Thanks. Could you update us after you've driven a bit more? I find ride comfort generally okay, the biggest complain is as I said, being a bit crashy over harsher imperfections. I guess a lot of that it low profile tyres, but if these help with that, I might be interested.@Conscript I ordered from blackhawk, the cost was £660 including the door stabilisers, that's with shipping, tax and import fees. The yen is weak at the moment so the exchange rate is really favourable.
Like your thinking @Nick63 - I've found some nice 22mm Blue hose on AliExpress that'd brighten up my engine bay at the same time. Did you use a heat gun or hot water to expand the tubing? EDIT: Must have been typing my reply just as you were posting the above. I've plenty of PTFE spray in the garage so that should suffice ...
I'll just need to find the torque figures for those nuts now... Found it. 16Nm.
Yes, but I couldn't be arsed with undoing all of the nuts as I'd already fitted my Cusco bar; so I split the hose with a stanley knife, wrapped it around and used tie wraps to secure in place. See my image in the 'Keeping Engine Bay Clean' thread here.Did you end up fitting the 22mm Blue hose you ordered up? Considering buying the same stuff myself.
Cheers.
Many thanks - and that's a great idea. Right, that's the same one ordered up and I'll take the same approach, much easier. Have you noticed any difference to the droning? I don't expect it will make much difference to the overall noise until I change the tyres but the lack of the resonance on certain motorway surfaces would be nice.Yes, but I couldn't be arsed with undoing all of the nuts as I'd already fitted my Cusco bar; so I split the hose with a stanley knife, wrapped it around and used tie wraps to secure in place. See my image in the 'Keeping Engine Bay Clean' thread here.
