mackie
Anyone got an insight on the Godspeed kit that uses Clio/A110 Brembo 4 pots? Seems like a good value option vs the AP kit but there has to be a downside right?
They are a bit of an unknown, piston sizes etc and I'm pretty sure it's been said they use an odd sized pad, something from an Aston Martin maybe. @Will300 is the brake man he might remember.Anyone got an insight on the Godspeed kit that uses Clio/A110 Brembo 4 pots? Seems like a good value option vs the AP kit but there has to be a downside right?
That's not really an upgrade. No weight savings, no increased thermal capacity or braking force, you'll just trade off the safety of the OEM brakes for some slightly better looks (and even that it's subjective).Anyone got an insight on the Godspeed kit that uses Clio/A110 Brembo 4 pots? Seems like a good value option vs the AP kit but there has to be a downside right?
What makes you think there will be no weight savings? The calipers are aluminium and so are the disc bells. They will be lighter than the stock steel setup without a doubt, you are also increasing the size of the pad and disc rotor so you are increasing the thermal capacity too.That's not really an upgrade. No weight savings, no increased thermal capacity or braking force, you'll just trade off the safety of the OEM brakes for some slightly better looks (and even that it's subjective).
My bad, I thought he was reffering to the k-system kit, which is using the stock rotors and steel for the brackets (hence my comments).What makes you think there will be no weight savings? The calipers are aluminium and so are the disc bells. They will be lighter than the stock steel setup without a doubt, you are also increasing the size of the pad and disc rotor so you are increasing the thermal capacity too.
Only 1.5kg? Per corner I hopeI think the piston sizes are the same (40mm) but despite the big price difference I’m more inclined to go with the Reyland AP kit as it’s a proven known quantity and they use a standard AP ring size so there’ll never be any problem with getting spares.
I’d estimate the AP 330mm kit probably saves at least 1.5kg over stock, plus my new wheels being ~1kg lighter that’s a very worthwhile drop in unsprung weight.
Anyone knows if the Reyland Track 330 BBK fits either of these wheels?
- OEM 18x7.5 ET48
- OZ Alleggerita 18x8 ET48
- Enkei RPF1 17x9 ET35
A better option would be the Megane RS callipers on STI rotors (if you can stomach the weight increase), but I cannot find a ready-made kit.
Thanks for this, it's really helpful!!Big Brake Kit - Spreadsheet (UPDATED!)
I've updated the spreadsheet with a new share link please see above.
If you want to know what I've updated, check the version history tab.
That EBC kit appears to be an even better option than Reyland (no negatives, better price). That "8 bolt PCD" issue does not seem to be an actual issue, if you look closely at the photos on their site, one disk has 5 holes and the other 8 (in the same photo) and also they are selling both as replacements (decent prices too).
Can't find any reviews though (at least on 86).
As I mentioned, I'm not even sure the kit for GR will be delivered with 8-hole rotors, since in the same photo on the product page there is 1 rotor with 5 holes and another one with 8.Its only an issue when you come to buy replacement discs, as they are a unique PCD, they've locked you into there platform. Thus you are limited to EBC's stock level and EBC's prices. If you go to order a replacement disc right now on their website (https://ebcbrakesdirect.com/boxed-330mmx28mm-sg-grooved-replacement-disc-ring-lh), they currently only have 1x LH disc in stock at: £197.30. If you need a RH disc (https://ebcbrakesdirect.com/boxed-330mmx28mm-sg-grooved-replacement-disc-ring-rh), there on back order.
With any of the AP Racing kits or kits that run Brembo calipers, you can run discs from multiple manufacturers, i.e. Reyland, Godspeed, AP Racing, PFC, DBA and a loads of others, so your not locked into one manufacturer.
EBC had a mega black friday offer on them and I was seriously tempted, but the lack of disc choice and availability put me off.
I'm aware of one person who's running them, but he doesn't do any trackdays. So no idea on durability.
He is referring to the bolts for the disc rotor to the bell. They use 8 bolts, which is less common and bespoke to EBC.As I mentioned, I'm not even sure the kit for GR will be delivered with 8-hole rotors, since in the same photo on the product page there is 1 rotor with 5 holes and another one with 8.
Even if the kit is being delivered with the 8-hole rotors, I think those extra holes are for compatibility with different PCDs (for different cars). It's not like you'll suddenly have 8 studs on your hub and can't fit 5-hole rotors from other manufacturers)
I must be missing something as I don't understand why do you think you're locked in their platform...
- pad type: PFC: 0929 (OEM) is ~115x48mm
I've updated the spreadsheet with a new share link please see original post.
Probably overkill if no one is overheating or melting the dust boots on their CP9200s but I'm interested in your thoughts.
