Okay, bit of a boring thread, but hear me out, and help make a decision so that I can spend my hard earned cash on something better than our new (used) Skoda Enyaq
I'm going get KW V1 coilovers installed on my GR86 and drop the ride hight approximately 1 inch (25 mm) from stock.
Along with this my plan is to get extended wheel studs installed, to get the desired stance on both my winter wheels (on OEM rims) as well as for my summer set (OZ Leggera rims). Everyone seems to swear to ARP extended studs, but they seem to be quite expensive in Europe, and I would be happy with something else, as long as they are from a reputable brand. I would use open ended lug nuts on the summer setup.
The fitment that I'm after is the following:
H&R does seem to have this set (though it doesn't come up as an approved set for the car), which is 20 mm slip-on spacer with included extended studs, all in the correct size I think: https://www.h-r-shop.com/h-r-wheel-spacers-5x100-56-drs40-20mm-p-581174.html
As I see it, I have the following options:
Picture of the summer wheels to spice the wall of text up a bit:
- Summer setup:
- Rim: OZ Leggera 18x8 +45
- Spacer: 12 mm slip on spacer on each wheel
- Combined difference from stock: Outer edge of the rim will be 21.4 mm further out than stock
- Winter setup:
- Rim: OEM 18x7.5 +48
- Spacer 20 mm slip on spacer on each wheel
- Combined difference from stock: Outer edge of the rim will be 20 mm further out than stock
- Go ARP extended studs (3 inch), and stand-alone slip-on spacers. I've found these:
- Go with the H&R set off 20 mm slip-on spacers and extended studs and find a 12 mm stand-alone spacer for the summer setup
- H&R: https://www.h-r-shop.com/h-r-wheel-spacers-5x100-56-drs40-20mm-p-581174.html
- 12 mm: Same Muteki as previously mentioned or if anyone knows of another cheaper good quality 12 mm spacer?
