Yeah the GR tends to overspeed uphill due to the less nuanced throttle modulation. I also like my previous manual car where I could use the clutch and change gear without CC disengaging.
In terms of where it could be more logical, it's things like the set function only works when CC is on, but not engaged - if you manually change speed due to a change in road speed for eg. you cannot set at the new speed without cancelling first and then setting, because set is the same action as decrease speed. Also the cancel is pulling the stalk towards you, but to resume you don't do the opposite, you instead have to push the stalk up. Plus the whole having to turn it on/off via a side button press is a bit superfluous (though they're not alone in that regard).
