66A5DEDC-DB7B-4DF4-837B-926456A3900A.png7BDE7133-7E9F-4211-B20A-B62192A67670.jpegCBB2BD2D-AD12-4170-B5DA-5AA0EC66A1A3.jpeg32EF3063-80DD-4E40-AC10-83BE26F3C63B.jpeg21687594-7B0B-4736-848C-54669A34DD83.jpegD3AC6146-1A95-4578-AB1C-41D63D4B4AAC.jpeg85A675A0-636A-460F-BAFC-0E5CFFA40EB6.jpegB3B6E57F-0707-40E8-8C11-E9234CB6E012.jpeg39E9D770-3D67-4F73-BE7F-36F501EBDC85.jpeg9C798117-6A8B-4238-8185-6EC358C6A29E.webp
Just to note it’s not good for the engine to have it “warming” at idle. You’re much better jumping in and driving off being sympathetic until the oils up to temp.
It's only recently that I've discovered why - at low engine speeds the oil pressure is lower, and the cleaning properties of petrol means that the oil film in the cylinder can be being removed more quickly than it is being replaced.
Once the engine speed increases, the oil supply increases too and protects the cylinder/piston/rings.
Of course, this doesn't help when the car is frozen solid and you need it to defrost before driving off. Perhaps sitting in and holding revs above tick over might help :)
Some scenarios are unavoidable (although scraping is quicker) but if there’s an easy option to jump in and go then it’s best to take it.
We also need your wheel details and specs.
They look bang on mate 👍🏼🥰
Hi Mate, I currently have 3 sets the ones in the photo’s are Rotiform LAS-R with Aerodiscs as there’s only 2 that you can use the Disc’s on and are pretty cheap set for shows and meets etc..
Koshi extreme forged carbon bonnet, Airtec oil and intercooler, Airtec quick shift, Eventuri, Enhanced performance full system inc Opf delete and sports cat, Full rear audio build, Starights, Greedy steering wheel, Recaro cs Sportsters, OMP 4 point harness, Litchfield remap not the box, Full carbon engine dressing, RSic6 Vented wings, HTA rear spoiler, Eibach pro lowering springs, de-wrapped roof, Toms side skirts, TRD front splitter, rear Toms ducts, can’t think of anything else..😂🤔
Surely the lower oil pressure only matters when it's up to temp? Cold start oil pressure is pretty high
Perhaps I meant flow.
Whatever, my understanding is that idling on a cold engine can cause petrol to dissolve some of the protective oils on the cylinder walls that aren't replenished as quickly as when the engine is warm.
It's possible of course that this is all complete bollocks and an internet myth.
might be on older cars that run really rich but modern cars dont really suffer from petrol dilution of the oil
