N17whitehartlane
- Nov 11, 2022
- 282
- 538
This is epic, Spurs fan spending money and wisely .
It’s to keep my depression at bay being a Tottenham fanThis is epic, Spurs fan spending money and wisely.
Not the greatest photo’s as it’s is a videoIt’s to keep my depression at bay being a Tottenham fan![]()
Just to note it’s not good for the engine to have it “warming” at idle. You’re much better jumping in and driving off being sympathetic until the oils up to temp.
It's only recently that I've discovered why - at low engine speeds the oil pressure is lower, and the cleaning properties of petrol means that the oil film in the cylinder can be being removed more quickly than it is being replaced.
Once the engine speed increases, the oil supply increases too and protects the cylinder/piston/rings.
Of course, this doesn't help when the car is frozen solid and you need it to defrost before driving off. Perhaps sitting in and holding revs above tick over might help![]()
Hi Mate, I currently have 3 sets the ones in the photo’s are Rotiform LAS-R with Aerodiscs as there’s only 2 that you can use the Disc’s on and are pretty cheap set for shows and meets etc..We also need your wheel details and specs.
They look bang on mate![]()
Koshi extreme forged carbon bonnet, Airtec oil and intercooler, Airtec quick shift, Eventuri, Enhanced performance full system inc Opf delete and sports cat, Full rear audio build, Starights, Greedy steering wheel, Recaro cs Sportsters, OMP 4 point harness, Litchfield remap not the box, Full carbon engine dressing, RSic6 Vented wings, HTA rear spoiler, Eibach pro lowering springs, de-wrapped roof, Toms side skirts, TRD front splitter, rear Toms ducts, can’t think of anything else..We also need your wheel details and specs.
Need one if you‘ve got a spare or just a donation to the GR fund pleaseWhat about a bank robbers mask![]()
Nice to see you made the right choice on cars, shame about your taste in football LOLSold my Porsche to funds this![]()
Surely the lower oil pressure only matters when it's up to temp? Cold start oil pressure is pretty highIt's only recently that I've discovered why - at low engine speeds the oil pressure is lower, and the cleaning properties of petrol means that the oil film in the cylinder can be being removed more quickly than it is being replaced.
Perhaps I meant flow.Surely the lower oil pressure only matters when it's up to temp? Cold start oil pressure is pretty high
Whatever, my understanding is that idling on a cold engine can cause petrol to dissolve some of the protective oils on the cylinder walls that aren't replenished as quickly as when the engine is warm.
It's possible of course that this is all complete bollocks and an internet myth.
