GR86 The number plate thread
Received and part number is correct for JDM size plate holder.
Great stuff Did you just order this through your local dealer? And where will you source plates the correct size? I have a five digit reg and assume this will be the best solution, what dimensions should the plate be to fit? And what are you doing for a rear plate, standard size or similar? Cheers
I did yep.
Not sure there's a correct size but on someone on heres advice I ordered 355 x 111 from https://www.platesforcars.co.uk/ for my 5 digit reg.
This plate holder is not a perfect solution but pretty good as you can see on post #55
Rear plate for me is same size, but will go into existing holes for me, as the rear has holes from factory.
I did yep.
Many thanks, would a 330 x 111 plate be a better fit? Cheers
Could someone recommend a good sticky tape for the number plates that's available on Amazon, please? Want to get one before collecting my car.
As there is already a mounting plate for the front, I assume there is no issue with screwing the plate on the front?
I was thinking of only using sticky tape for the rear - is that what others are doing?
Another option is 3M VHB tape or Tiger Tape.
Fitted the US spec front plate mount today when I picked up my car and it works a treat. Decided to get a 330mm wide plate and it’s a perfect match.
I did yep.
I have a 355 from them too (actually 355.5), looking at how it fits the US mount I'm wondering if the same look could be achieved just by cutting a bit off both sides of the UK one? Even if the edge isn't perfect it wouldnt show?
After a good chat with a very helpful parts guy I can confirm the Toyota UK part number is: SU003-09277
This is for the JDM size plate holder as above. £40.03
Still thinking about this. Was this for the 330x165 standard JDM sized plate?
Looks like a 330 x 110 to me.
@Wrobz Where did you get your plate made up please? I've got a 330 x 110 for the rear but never got a white front one done for my registration and now the place I got mine from doesn't do a standard height (110) but only 330 long :cry:
330 x 111mm from these guys:
Fits the JDM/US plate mount perfectly for width, there are also some “blips” to catch the bottom of 111mm tall plates too so looks spot on.
You could probably cut down a standard mount but it will look a bit of a mess and you loose the bottom pieces that clip to the grill.
Excellent - thanks for the headsup.
My dealer doesn't understand part numbers though - couldn't order a duckbill when I even gave them the part number so will try another dealer I think!
(y)
(y)
To be fair, the UK spoiler numbers are different to what have been put on here previously. Well, the first part is but the latter part is still the same (the colour).
The size of the part is 300 x 127 - same height as the UK holder but much less wide.
I assume the JDM plates just hang off the bottom a bit?
