ArfurAnt
Devoted member
Great stuff Did you just order this through your local dealer? And where will you source plates the correct size? I have a five digit reg and assume this will be the best solution, what dimensions should the plate be to fit? And what are you doing for a rear plate, standard size or similar? CheersView attachment 9945
Received and part number is correct for JDM size plate holder.
