GR Yaris Plugs
What is the stock plug heat range?
EDIT: 8 apparently
It’s 9
I went 8 because I wanted to try colder plugs as I’m running more boost and our fuels in Aus seem of questionable quality at times
The OEM plugs that came out of my 2020 GRY were NGK DILKAR8U7G so the heat range is # 8 .
I will stick to OEM plugs and when Toyota recommends for replacing them, I know it’s a rather large interval but the engine still runs great and they know how to take care of the engine better than anyone in stock form.
Interesting comment.
I'm not sure I would even trust Toyota dealers to wash my car and even that job only gets done a few times per year.
This is where I purchased mine from. They are a GR specialist. The site says they have two types. One for stock and an other for modified
I went with the colder ones
What gives
I wasn’t referring to the dealers specifically (there are good and bad ones) but to Toyota engineers who designed the engine and maintenance schedule together in order to have a reliable engine on stock form…
Fair point and I agree that it's worth keeping things separate in our minds when it comes to the different Toyotas (manufacturer, dealers, etc).
Having said that, the Toyota manufacturer, while much more trustworthy than most dealers in my view, can get it wrong too, or at least not perfectly right :)
They're also human and subject to constraints of their collective operating model (eg what reaches us is not just the result of engineers' thinking, but also lots of other functions, like finance, etc).
The full details of MK2 will perhaps demonstrate what Toyota could have got (even) better with the MK1. Other examples include no mention of a running-in service in the manual, a questionably lengthy interval for the rear diff oil change, etc.
So, just like I choose to baby my car by changing the rear diff oil earlier than the Toyota schedule prescribes (so that I get the most out of it and look after it), I change plugs earlier if time and money permits. I still trust Toyota that if I go by their schedule intervals, the wheels won't come off :ROFLMAO:
My participation in this forum is largely for that niche element, though; info that goes beyond what I can find in the owner and repair manual. As well as insight other and/or earlier than what I get through official sources (and thanks for that, by the way!).
Its a 15 min job for any enthusiast to change plugs and the difference is remarkable.
Not sure why you want the car to be unhappy just to praise the Toyota dealer service schedule?
Does anyone have a good EU supplier for the ruthenium plugs mentioned earlier in the thread?
At about 35,000 km I've noticed starts taking half a revolution or so more than they used to and a few € chucked at plugs can hardly hurt.
Ordered from local dealer here 60€ for 3 plugs + delivery.
Let us know what you think once you install these.
Just ordered some in the UK, I’ve had a misfire happen a few times and then not occur for a while but if you leave it for a few days it has trouble starting or cold idling. Originally i thought it was a coil pack but reading the stories here and being around 36,000 miles plugs sound like the solution.
Obviously I could take it to a dealer for warranty but the cost and time for plugs or a coil is probably break even.
