It’s 9What is the stock plug heat range?
EDIT: 8 apparently
I went 8 because I wanted to try colder plugs as I’m running more boost and our fuels in Aus seem of questionable quality at times
EDIT: 8 apparently
at least at our workshop its every 100tkm.What’s the service schedule for plugs?
Interesting comment.I will stick to OEM plugs and when Toyota recommends for replacing them, I know it’s a rather large interval but the engine still runs great and they know how to take care of the engine better than anyone in stock form.
The OEM plugs that came out of my 2020 GRY were NGK DILKAR8U7G so the heat range is # 8 .
I wasn’t referring to the dealers specifically (there are good and bad ones) but to Toyota engineers who designed the engine and maintenance schedule together in order to have a reliable engine on stock form…Interesting comment.
I'm not sure I would even trust Toyota dealers to wash my car and even that job only gets done a few times per year.
completely agree, changed at 30k and instantly improved start up and idle, Toyota's schedule is way too far, same for oil and aux beltChanged mine at 20k and the diference was noticeable. The right torque for sparks is 20Nm and 10Nm for the coil bolt.
When to change aux belt?completely agree, changed at 30k and instantly improved start up and idle, Toyota's schedule is way too far, same for oil and aux belt
no real fixed time but avoid disappointment say around 40 or 50k miles or 80k kmWhen to change aux belt?
Was there reg. Service interval for this?no real fixed time but avoid disappointment say around 40 or 50k miles or 80k km
100.000 km both plugs and aux belt.Was there reg. Service interval for this?
good - aux belt I leave for Toyota guys but maybe change those super plugs at 70tkm or smth, just out of curiosity.100.000 km both plugs and aux belt.
Ordered from local dealer here 60€ for 3 plugs + delivery.Does anyone have a good EU supplier for the ruthenium plugs mentioned earlier in the thread?
At about 35,000 km I've noticed starts taking half a revolution or so more than they used to and a few € chucked at plugs can hardly hurt.
Let us know what you think once you install these.Ordered from local dealer here 60€ for 3 plugs + delivery.
NGK - LKAR8BHX - NGK Ngk Spark Plug Stock # 91784 | Spark Plugs | Laukkanen Motorsport English
Buy NGK - LKAR8BHX - NGK Ngk Spark Plug Stock # 91784 quickly at a low price in Laukkanen Motorsport. Click and order now or visit our shop. Spark Plug - Ruthenium HX - 12 mm Thread - 26.5 mm Reach - Gasket Seat - Stock Number 91784 - Resistor - Each Additional information...laukkanenmotorsport.fi
Just ordered some in the UK, I’ve had a misfire happen a few times and then not occur for a while but if you leave it for a few days it has trouble starting or cold idling. Originally i thought it was a coil pack but reading the stories here and being around 36,000 miles plugs sound like the solution.Ordered from local dealer here 60€ for 3 plugs + delivery.
