Some track testing from few mo ago
With Cusco hub and GRMN gear set
500NM at front wheel
I don’t really track my GR Yaris at summerHave not see you around for a while now. Did you fix your engine yet?.
What is ur set up@Diyman25 hi, even if not tracking your GR Yaris through summer, how many track hours have you done already on it since installing the Cusco hubs?
Reason I am asking: I am getting more and more issues shifting from 2nd to 3rd under hard acceleration. coming home from a track day where it did get worse and backing up to my garage I heard concerning noises coming from the drive train and a strange binding from the front diff. my bet is I will find some damage on gearhubs and the gearbox overall :-/
Engine is still stock, however wheels are 18x10 with 265/35 R18 tiresWhat is ur set up
Tire size , power wise (TQ)
it happens only on 2nd to 3rd, under load. maybe 1 of 5 shifts. sometimes I can reproduce, sometimes not.On 2-3 difficult gear up shift
Is usually not the issue I have in this thread
More like drive error
On my experience Gr Yaris Syncro could. Be fragile and not helping when Toyota put a plastic shift pad in shift fork
That is some nasty failure on that lsdit happens only on 2nd to 3rd, under load. maybe 1 of 5 shifts. sometimes I can reproduce, sometimes not.
end of last year I was coming home from a track day with a buddy of mine, same car, stock power. he got similar noises coming from gearbox and front diff as I have now. after few kms he got stuck with a completely locked drive train. result: 2nd shattered, torsen to pieces:
I will see what awaits me, in case the transmission dies on me, I will try to rebuild with the cusco hubs.
Glad u find the issue of ur problemon a side note: I attended a trackday this weekend, as a preventive meassure I decided to change the transmission oil after appr. 10tkms (which was just dark, but nothing extraordinary). while having the car stripped and on jack stands I decided to check the transmission mount. the 4 screws holding the aluminum bracket to the transmission body were completely loose - just slightly above hand tight. the screws going to the car body also very loose. I added a generous amount of blue loctite to all the screws and retightened. it solved 90% of my 2nd to 3rd upshift issue.
hydraulic jacks? nice...Friend Gr Yaris power by GCG28R been back with rebuild Cusco hub sleeve and change back to dual mess flywheel , test one session with 295 Nankang CRS
No issue on transmission yet View attachment 31933
What were your findings with the Cusco hubs? did those break as well before you changed to 7speed Seq?To any one still follow the thread
Some thing update , in order to be fastest time attack machine in Taiwan
Choose some thing more suitable for track is need it
This time attack season I will move to 7speed Seq
Hope this thread will help whoever have transmission issue on their track Gr Yaris
Stay tune for more news on my time attack Gr Yaris
