GR86 Coding via service departments.
The car has to be properly 'ON', but not running, so 2nd click. The VCI will then communicate with the car's ECU. Most changes can be done in less than 10 minutes so your battery should be okay. I've helped a few other GR86 at car shows and they've always been fine...
System is really slow, but I think I'm literally 1 click away, I get to utility but there are no options :unsure: Still sat and waiting for a while but doesn't populate.
Running version 18 too so no idea. How long did you have to wait for the screen to populate?
Good call, @chopper602 (y)
Got it done, thanks guys especially @Sonic for the tips. When you get to the screen above you have to click unit customizing and another screen pops up in the middle to select.
Works a charm now - windows both activate with long press of the button and unlocking now unlocks both doors.
Top tip, I trimmed the connector cable tab so that it wouldn't get stuck like others have.
Cheers.
