GR Yaris Balance of tuning and durability limits
Nice to hear, watching this with interest. How do you feel it compares to before the turbo change?
The most surprising change is the aural experience since upgrading the turbo. The intake wooshes were almost embarrassing with the OEM recirculation, Artec uses an external setup which sounds more civilised. Same with exhaust volume. Something about the way exhaust is flowing though now means the volume has dropped somehow. Tune still ongoing so data collection is a few weeks away yet.
I use the turbo smart plumb back on the OEM turbo and you are correct. It is less active than the OEM and less vocal. I think it releases the back pressure much faster. Low velocity but a larger mass flow hence less noise
Im thinking about getting the plumb back too but is it better than oem ? I'm not sure doing a remap either . I have an eventuri and would love to have a nice stututu đŸ˜‚
Ai explains haha:
Yes, a bigger turbo running at lower pressure is usually quieter than a smaller turbo running at higher pressure.
Why the Smaller Turbo is Louder
    • High restriction: A small turbo has a small exhaust housing.
    • High backpressure: It traps exhaust gases and creates high pressure behind the engine.
    • Sharp sound: Forcing gas through a tight space makes the exhaust sound louder, sharper, and raspier.
Why the Bigger Turbo is Quieter
    • Easy flow: A big turbo has a larger exhaust housing.
    • Low backpressure: Gases move through it smoothly with less pressure.
    • Deeper sound: Less restriction results in a smoother, softer, and often deeper exhaust note.
I would agree with that. Mine was louder before the HJS, it was louder with the OEM recirculating valve and before changing the turbo inlet pipe.
Car has fresh plugs and fresh oil as of yesterday. Went out to log revision 8 as it was dry. While doing so, ended up running some pulls with an E63 S. The GR Wasn't too far behind, he was somewhat shocked!
