Thanks, but I am just going to leave it for now. I should have a new exhaust arriving in the next month or so anyway, so don't really anticipate wanting to experiment with it further - I'm already happy enough as it is fully off. Appreciate some might prefer to keep is just at the lowered volume though.
Not very well
The connectors are supplied separately as a male/female pairing with cable tales already attached to each of the 16 pins.
- First thing I did was identify which of the cables would be unnecessary and just cut them off (see
@FRAJ's excellent pictures above my post. As you can see, the existing connector only has 8 wires and
@86GR already detailed what they are earlier).
- Once I'd removed the unnecessary wires from both connectors, I then soldered the remaining tails together so they corresponded - so what you're left with it essentially a short passthrough loom which sits between the existing male connector and the female socket on the ASC module.
- As 86GR said above, the yellow/green wires are the speaker positive/negative. On my new loom passthrough, I cut the cable which corresponded to the green wire and attached each end to the little rocker switch.
Apologies - I should perhaps have documented things better as I went. But, being honest, this is a lot of work for what it achieves, so I didn't think many would want to emulate it. It would probably be easier to just unplug the thing, take it for a drive, and then plug it back in. Especially for you Kosh - your vehicle is left-hand drive, so I think the connector is even easier for you to access - for RHD cars, we have to take the glovebox out.
