Altocumulus
Dedicated member
- Jul 16, 2024
- 133
- 217
Ecutek can do flex fuel now.Eventually, probably yes. That or a E85 flex tune if that was/is available.
If getting a good gasoline map is tricky, flex fuel makes that 10x harder though if done properly. But yeah, that would have been my goal, happy not to have to do it again though, it always takes some nerves and time.Ecutek can do flex fuel now.
On my M5 the BMW ECU was very responsive to octane. You could introduce ethanol or octane booster and it would add timing itself with each pull. I'm curious how much adaptation the GR ECU allows with non flex fuel ecutek calibrations?
Hey how you doing ? I just finished instal the airtec oil cool , what temp do you have idle and normal driving never going above 80 degrés is it normal ? And i have max 4.5 bar pressure full loadI have:
Whifbitz resonated GPF delete
Whifbitz resonated backbox
Eventuri
Airtec inlet manifold
Airtec oil cooler
Airtec gearbox cooler
Airtec cooling pack replacement rad
Airtec turbo elbow
Airtec turbo pipe
Airtec diff cooler
Airtec intercooler
The Airtec thermostat opens at 80c according to their fitting instructions, so that is 'normal' operating temperature.Hey how you doing ? I just finished instal the airtec oil cool , what temp do you have idle and normal driving never going above 80 degrés is it normal ? And i have max 4.5 bar pressure full load
needs to be on the car firstReady for the next phase
its all setup dependant. I did my previous car with professional shop TVS racing in NL - the setup took all day and in the end they said honestly that if you will run longer periods WOT car needs lower compression pistons. If your tuner don't know the use case the car will be used, or if they don't say to you to what driving setup it is built, it will be hit and miss.Hello everyone. I did my Yaris GR 2023 @ JRM Racing in Sweden (Stockholm). They did OPF-delete, Milltek exhaust, new intake from DO88 and then remapped the car with ECUtec. I got 323hp after the tune and the car pulled superhard in the top revs. The car worked perfect, I did the tune when the car was run in, maybe 2000km and sold the car with 10000km on it. I did several track days with not problem at all.
I know this thread is about tuning and ECUtec but im planing on buying the new Yaris GR and I will not tune it. The reason is that when i tuned my last one i didn´t know i would track it. But once I took it out on track then i was hooked, the car is designed to go on a track not to go and buy groceries or do roadtrips. And in the long therm my belif is that the small engine will last longer with original power. Especially if you are hammering it on the track.
1.65 bar / 24 psi peakwhat boost levels is ecutec tuners running with stage 2+ cars hitting 330-350hp?
curious to know the boost levels there.
