GR Yaris GR Yaris and oil pressure (in track use)
I think an extra 0,5 litre will help prevent that
I dont feel comfortable adding an extra litre over the 4.3l (as I am already overfilling by 0.5l)
I'll ask what my workshop thinks about it...
at least on track it is not sufficient especially with hot oil. tested last summer. My oil gauge went all south in hard braking and thus decided its not safe to track the car without baffles. Everyone has of course own limits but I prefer to run it on safe side. Much more fun to drive as you dont' constantly need to keep on looking at oil pressure gauge.
Completely agree
On my typical fast laps I dont get oil starvation (presumably because of smoother inputs) but I am not tracking the car until this gets solved
@Michael Knight , have you perhaps measured/logged oil pressure pre/post baffle install?
Completely agree
Nope - as have not driven hard with baffles. Too slippery
I've managed to reproduce an oil pressure issue on a public road with standard size winter tyres 😨
Stock car, 0.5 liter overfill, changed every 5k km
Just slammed on the brakes really fast at around 100km/h in 3rd gear for 1-2 seconds
I agree its not a typical use case, but I'm starting to worry...
What viscosity oil u are using
I been using 5/50 , and did not see this dramatic oil psi drop
I had a low oil pressure situation on track again (1.1 bar)
This time I also logged RPMs
Oil overfilled by 0.5 litres, oil temp was 116°C (still Toyota's 0W-20 API SP)
It happened in a right corner, around 115km/h, 1g
It seems as if it happened right when I took a curb, but thats what I always do and I dont often get starvation
It is at 0:26 in this YT video
I have already reported it to Toyota, they forwarded it to HQ, waiting for answers
I'm leaning towards a baffled sump, but am slightly worried about its rubber parts, also waiting if that will void my warranty...
Is this a combined G (lat-long) graph?
Edit: looking at the video I believe it is combined G.
By any chance you could generate similar graph with longitudinal acceleration?
It seems that oil pressure recovers during even higher G on a right hand corner but dips again on next braking.
You are totally right
Later on I have a much higher combined accel of 1.35g and no issues
This is really braking + right corner related
Green longitudinal
Blue lateral
Outside of hydraulic actuators, like the VVT actuators, chain tensioner, etc., the function of oil pressure in the engine is not directly to keep the metal bits from rubbing together, but to supply new oil to the friction areas, which has the effect of keeping the metal bits from rubbing together.
Five bar does not hold the crankshaft rod pin away from the bearing. The pressure in the loaded area in clearance is much higher than that. It's the oil film's job to do this. The oil pressure then replenishes dislocated oil with fresh when the clearance opens.
With a momentary drop to 1 bar, oil is still being supplied to the places it's needed, just not in the same volume. To do that over an extended time is detrimental because the oil is also what cools these friction surfaces. With 1 bar of pressure, oil is still being replenished in the clearance, but not at a rate that will prevent the parts heating up to a point where oil shear will occur. A momentary drop is nothing I would be concerned about. An extended drop, like the entire braking zone, or the entire time the car is accelerating off of a corner, is a problem. Any drop to zero is a potential problem, as there's no oil to replenish what was lost on the last sweep...but there's still oil there.
This oil volume and replenishment is also the primary reason we need to look closely at the effect of going to a higher viscosity oil. If our oil pump pressure regulation valve opening pressure hasn't been adjusted to run higher pressure, then there is less oil volume being supplied to the clearances that need it, and to the pistons through the cooling jets. "Thicker" oil won't go through the same gap at the same volume at the same pressure as a thinner oil. So when the oil comes to pressure, more of it is simply bypassed back to the pan. This also creates heat, as heat in a hydraulic system is also generated by oil that's returned to low pressure without doing work. This isn't saying not to use #50 oil, only that you better be sure the volume supplied to the places than need it is still adequate. There's a lot more to it that just shear.
That said, I can't count the engines I've inspected where it lost an oil pump at high rpm and load, where the engine was shut down immediately, and no bearing damage occurred. I've also yet to see a wet sump engine where we logged a fast-acting sensor on a high sample rate logger or scope, not lose oil pressure from time to time. This is primary reason real race engines use a dry sump.
I guarantee you that every rally car on the planet without a dry sump has near-zero oil pressure drops when they go zero-G.
Anyway...my ¥2
Anyway...my ¥2
Good points. what is the limit of oil thickness is a good question. assuming 5w30 is ok for summer/track use as the viscosity is more or less the same when hot as 0w20 in normal temps (including -20'C that is considered also normal), but of course it is not the same what factory has specced. When driving hotter laps last summer oil pressure dropped quite low also on straights (little bit over 2bar) which feels really low. that was not much g's loaded scenario. would like to keep pressures above 3bar but not sure if that is really a issue or just a conern from habit. rule of thumb in old cars was 1bar x xrpm is ok, but this is an engine from different time so maybe it doesn't follow this logic when running hot.
In manual oil pressure should be min +2bar when driving (not idling). with 0w20 hot day scenario it was getting close to this limit.
I’ve been suffering from syvecs limp mode on track - is there any down side to overfilling oil? I have had mixed results with overfilling, am in the process of installing a catch can, and might try slightly thicker oil, but I’m close to the point of going for an accusump (as mentioned above), decent writeup here.
The only dry sump option I’ve seen is this one - mega expensive before transporting halfway round the world, and means losing aircon, which I’m really not keen to do.
Why not to just add those baffles - its not so expensive option.
Higher viscosity might increase pressure. Gives less leakage at the oil pump, at the same time it resists flow more, so unsure the actual flow is improved.
Ref the oil film, main reason for low viscosity is high temperatures, too low viscosity can compromise the oil film. High temperatures can also cause oil to degenerate, also causing lower viscosity. Increased oil viscosity might help a little but does not adress the oil temperature, what viscosity an engine needs is determined by the gaps and tolerances.
Now viscosity is high at low temps, and increasing the number before the W with thicker oils means you further increase that high viscosity at low temps, possibly to a degree you make it harder for it to be replenished effectively in the small gaps of a modern 0w20 engine.
One might think a 0W40 could then be a solution, however the bigger the difference between the number before and after the W, the more viscosity modifiers are used and those are more sensitive to breakdown at high temperatures.
Esther based oils can resist higher temperatures better. Oil that has been too hot needs to be replaced. Oil analysis can give actual data on if it was too hot... That said I don't think 120°C or even 130 is an issue. Hot oil properties are referenced at 140 and 150°C. Those are upper end.
Also watch out that different (higher viscosity/esther) oils are still the correct spec, especially concerning LSPI (which can catastrophically destroy an engine) formulation.
Summary
Stick to 0w20, possibly 0W30 if you can find the correct spec.
Always solve the temperature issues first.
Change oils that were too hot.
Don't rely on higher viscosity as a solution for (very) high temps and directly related low pressures.
Never use oil that don't fullfil the spec (other then maybe hot viscosity)
Imho to my limited knowledge in the (huge) subject
GR86 community tried out some baffled sump mods on the track, logging oil pressure changes before and after. You can check these on the 900BRZ, BTR Justin, Track and Build YT channels. The results? Either 'nope, didn't work' or 'oops, made things worse.' Yeah, I get it, GR86 and GRY engines are like apples and oranges, plus the sump and baffle plate designs are different too. But these outcomes kinda make you wonder if the fix is worth it. It'd be cool if the baffle plate makers shared some data to back up their product.
ok thanks for the hint. need to educate. But overall different engines and baffles so not compareable directly. but good to know that it does not work everywhere.
I had a look at those GR86 baffled options and they don't make much sense to me so not surprised. The design that @Michael Knight has does and pretty sure that one works. Only concern are the rubber flaps failing.
