Fitted LED bulbs : Reversing lights, boot light, puddle lights and interior courtesy lights. 20 mins job and impressive results.
Fitted cargo net in the boot. Only a few £ from Aliexpress.
Fitted suede material to the bottom of the doors on the inside. Matches the alcantara on the top of the doors and stops those annoying scuffs on the plastic when getting out of the car. Again from Aliexpress and the exact shape as made for the GR86... less than £20 from memory.
On moving the car, I noticed a small damp patch on the drive (size of my hand). Checking underneath the engine bay I spotted a few drops of (hopefully) water tricking from a small hole (it's meant to be there) in the plastic tray underneath the radiator on the rhs when looking at the car from the front... wiped it and it stopped. I think it was only water as no smell, colour or texture. When I reached behind the plastic cover, there is a layer of foam sitting underneath the radiator that was wet. Has anyone else noticed this? I did about 100 miles yesterday with plenty of heavy rain so wonder whether it's simply the rain going through the front grill and collecting in this foam? With the bonnet up, I checked all the fluid levels and all at the 'max' other than the washer fluid bottle but I'm certain it wasn't washer fluid as I've refilled it and no leaks have happened. Thanks for reading my rambling.
