Michael Knight
Its pricey but good item. Bit difficult to install as fitment is so tightThanks for the informative reply. I think you may have convinced me to get the Forge carbon fibre one![]()
Will let you know the results over the next few weeksThanks for the informative reply. I think you may have convinced me to get the Forge carbon fibre one![]()
What u think to it?Its pricey but good item. Bit difficult to install as fitment is so tight
Hard to say really but at least IAT's are cooler. Best kit if you want cooler air with stock airbox.What u think to it?
Can u feel a difference?![]()
PETG does swell/degenerate above 70°C in presence of moist, FYI
I got a quote for printing Helmut Eder’s HelScoop #3 (3rd revision - scoop only)
Printed in PETG - £216 all in. Thought it was a bit pricey but I suppose the £400 Forge Motorsports one is the only other alternative.
18 months, while a good time, isn't anywhere near the liftime Toyota had in mind. So my comment should be seen in ~10 year perspective of possible plastics degeneration and has nothing to do with keeping short term shape.My PETG printed Parts don't change their Form in the last 18 Month!![]()
that reading (@boost gauge) seems as far I've ever seen mine...I just installed the Forge carbon intake upper box with filter and the carbon inlet dukt.
First startup after the car had a couple seconds of the hiccups. Was that just random? The turbo intake shouldn’t affect idle? I also felt as though the boost dial stopper a little bit before it used to before? I follows instructions to the point. Everything without anything going wrong. Is it possible to duck up such an easy install?
Hopefully this is just my paranoia and nothing to worry about.
I’ll attach a some a screeny from a video shot by my wife holding the phone inside the steering wheel. The run is done on a closed road to a power plant. Safest I could find and hopefully won’t start a whole thing about reckless driving.
Does the boost dial stop earlier than stock?
The Forge Carbon upper box uses a larger diameter pipe where the MAF sensor sits. This sensor is used to calculate the flow of air entering the engine, based on the air speed, air temperature and a known cross section - which you have now changed. So the engine is a ingesting more air than it thinks, making the engine run a bit leaner (=higher AFR) which renders some additional power (=quoted 13hp). The ECU still has the lambda sensor to sense the AFR and shouldn't let it go crazy lean. But still an added risk there.Thanks! Think I just need some reassurance here. I want to do stuff like these mods but strength after I get a tiny bit of panic. All I need now is for @Onehp to come on and say “It’s all good. Can’t really cuck anything up”
As OneHP mentioned, IF(?) the MAF tube is of different diameter (in comparison to oem) it may mess things a bit... usually bigger diam will lean-out the mixture and smaller: richer. But the ECU should have ways to adapt after a while.that reading (@boost gauge) seems as far I've ever seen mine...
PS: mine is stock, with just the front Forge air intake carbon (not the top air box)
Just need to plug the vacuum hose then.Regarding the lower-box flapper... mine is removed entirely (including the solenoid vaccum actuator + lower box inner insulation) without any issues.
That is not great news. Is your name Thor by any chance?Great news fellas!! The MAF sensor is held in place by two torq’s bolts. They need to be carefully tightened.
I just checked them today and they were coming loose. So I took a torq-bit and using two fingers tightened them again. On the second bolt the whole mounting cracked and came loose. So either I have superhuman strength or the mountings is way to fragile.
I can’t drive with air coming in after the filter so the car is basically scuffed. Will need to remount original box and return the broken one. Should be a warranty thing, right?
