At this speed, you might as well get a complete back-up wheel setBooked it in to have its summer boots fitted at 9am on 1 April.
Usually I'm lazy and drag my heels with the changeover but, as good as the winter Continental's are, I want this little puppy back on top form asap!
Noticed a deep slash on one of the Michelin sidewalls when I was wheeling them around the garage so I've ordered two new Pilot Sport 4S and will keep the good one as a backup, to go with the normal Pilot Sport 4 I already have which will now become my backup backup![]()
That was the plan last year, just never got around to it. This year I'll buy some winter wheels and fit the Continentals to them, then I can change them myself come October, which is what I've done with previous cars.At this speed, you might as well get a complete back-up wheel setCurrently, the biggest upgrade for this car would be 4 sets of wheels for me, to match different conditions.... cost and space bit lacking...
Do you find it is making tangible improvements? I'm getting an up-to-date map on the DTE once I'm fully familiar with it in its current state. be interesting to see if it makes any difference.Been optimising my programmable box tuning last days with some AFR tinkering using the MAF signal. Also new FW updates due to for the JB4 as they had a GRC to play with.
Yes it does. I'm using it mostly for some more top end power, stock will dump fuel (AFR 11) to keep temps down towards redline. Since I have better flowing and more heat resistant cat and other efficiency/cooling improvements, I figure I can keep AFR a bit higher and gain some power. At the same time realising that this engine doesn't have a real EGT sensor AFAIK so not doing anything silly, and keeping an eye on logs under varying conditions...Do you find it is making tangible improvements? I'm getting an up-to-date map on the DTE once I'm fully familiar with it in its current state. be interesting to see if it makes any difference.
Apart from anything else, it avoids Birmingham.
I'd recommend a slight detour for black mountain pass
Mountain Road Viewpoint
Google Maps
Find local businesses, view maps and get driving directions in Google Maps.maps.app.goo.gl
Iβm 5 minutes from the end of the M4 if you want a coffee stop.![]()
How do you measure your AFR's?Yes it does. I'm using it mostly for some more top end power, stock will dump fuel (AFR 11) to keep temps down towards redline. Since I have better flowing and more heat resistant cat and other efficiency/cooling improvements, I figure I can keep AFR a bit higher and gain some power. At the same time realising that this engine doesn't have a real EGT sensor AFAIK so not doing anything silly, and keeping an eye on logs under varying conditions...
Another good slight detour would be inland a little from Barmouth in Snowdonia - Mach Loop - where the RAF do low level flying training. If you're lucky you'll see a fighter jet or two. I had a very low Typhoon go right overhead on my maiden GR drive. Scared the s**t out of me.I'd recommend a slight detour for black mountain pass
Google Maps
Google Maps
Ah so it is, I always think it's closer to England than it actually isHah, it's already on there is you look carefullyThere's a dot where I redirected the route down the A4069
Yeah, M42 is a total chore of a road!
I haven't yet asked for the day off, because erm, it's the work meet up the day before and whilst they expect me to take four hours to get home, eight might be a bit of a piss take![]()
I'm also curious. You need a bluetooth OBD reader with suitable high speed readout and an app on the phone, e.g. Torque Pro. As a bonus they also usually work with e.g. carista. I have a OBDLink. Or a screen like CANchecked, unsure if that logs to a phone also. However do note that boost and MAF signals will be false on a v2.How do you measure your AFR's?
I am curious what mine does when my favorite map is set on the DTUK.
Your car is uncannily fast. I have quite some hardware (IC w BP, HJS, Intake) and it's about as fast. That said, it's not about not wanting to ask much of the engine, it's the opposite, I ask a lot from it with the right foot, love to rev it out as often as possible, and I want it to stay in one piece long term so not asking as much boost as perhaps possible everywhere...
Are these decals or actual doorhandles?
My Dragy still has not arrived, but I will when it does
