That's good going. I did something similar on a slightly downhill run myself the other day on 50 limit roads.Engine almost run in now. Surprisingly A road mpg first time is 52mpg average (50mph ish speed limit). Even with the sub optimal 95 octane I had to put in couple of days ago...
Mine is Auto.
Congratulations that’s Toyota Hybrid level mpgEngine almost run in now. Surprisingly A road mpg first time is 52mpg average (50mph ish speed limit). Even with the sub optimal 95 octane I had to put in couple of days ago...
Mine is Auto.
Thanks. We did some motorway driving today and hit the 1000mile while at it.Congratulations that’s Toyota Hybrid level mpg![]()
I'm the same, even with 4 tanks it's still showing a max range of around 270 miles. I filled up last night and showed 20 miles left with 1 bar on the gauge, but still no low fuel warning. I brimmed it with about 40L too. I wonder if it gets to zero on this range before the reserve kicks in and displays another 50 miles or so? Doesn't sound right though!From my second fill-up I got 301 miles from 42.26 litres which works out at 32.4 mpg which is exactly what the car's computer says, see pic below.
That's reasonably good but I'm still running in so keeping it below 4000rpm. I expect better once the engine's bedded in but maybe worse because I'll be using all the revs!
With similar gentle treatment my previous F-Type R (550bhp supercharged V8) managed 27mpg although it would dip quite low when the power was used.
Not sure why the computer was telling me there was only 8 miles range left when I could only squeeze in 42 litres. If there really is a 50 litre tank then surely I could have got another 50 miles out of the tank?
For the next fill-up I'm going to risk going past 0 miles and see what happens!I'm the same, even with 4 tanks it's still showing a max range of around 270 miles. I filled up last night and showed 20 miles left with 1 bar on the gauge, but still no low fuel warning. I brimmed it with about 40L too. I wonder if it gets to zero on this range before the reserve kicks in and displays another 50 miles or so? Doesn't sound right though!
Sent from my Pixel 6 Pro using Tapatalk
Pretty standard behaviour on modern cars - very pessimistic on the fuel level/range - leaving, typically, about 10 litres 'reserve'.Not sure why the computer was telling me there was only 8 miles range left when I could only squeeze in 42 litres. If there really is a 50 litre tank then surely I could have got another 50 miles out of the tank?
Not sure why the computer was telling me there was only 8 miles range left when I could only squeeze in 42 litres. If there really is a 50 litre tank then surely I could have got another 50 miles out of the tank?View attachment 13345
Take one for the team silver, plus you can write a good report for EVO!Risk aversion, that's what it is.
So who's brave enough to play 'chicken' with the range computer...?
Got too many watches as it is...Take one for the team silver, plus you can write a good report for EVO!
It was an anomaly!My other car is the same Jaguar you had.... and I've never seen 27 mpg hahahaha EVER. How were you driving this car lol hahaha... I'm lucky to see 13 mpg... on long run it'll hit 23-24 but I would dream of seeing 27. Was this downhill in neutral? hahah
