AK10TOY
I used my kerbing incident as an excuse to get them recoloured gold
Try using your indicator's it seems to help.Itโs not an issue with the car but the intrusive โsafetyโ features which are a result of the legislation. The lane departure assistant in practice can be far from safe. Yanking the steering wheel out of my hand whilst Iโm trying to pass a cyclist so that the car is now aiming back at them is just unsafe. Safety features work at their best when they are the least intrusive and work seamlessly in the background. Lane departure is usually an irritation and occasionally a danger, in all sorts of vehicles. I suppose itโll only get worse with speed restrictors.
exactly this, activating indicators cancel's lane assistTry using your indicator's it seems to help.
Well, you learn something every day. I didn't know that.exactly this, activating indicators cancel's lane assist
When I have lane assist on (usually on the motorway), I now indicate when pulling back into a left lane more than I used to do - because of the lane assist.exactly this, activating indicators cancel's lane assist
Oh the irony...When I have lane assist on (usually on the motorway), I now indicate when pulling back into a left lane more than I used to do - because of the lane assist.
Why? You don't need to indicate when pulling back into a lane you should be in...Oh the irony...
who'd have thunk it.....
lane assist can make you a slightly better driver
Where does it state that?Why? You don't need to indicate when pulling back into a lane you should be in...![]()
Well, I don't always indicate, but I do always take a quick sideways glance (which isn't necessary apparently). I've got those the wrong way round it seems!Where does it state that?
7. Multi-lane carriageways (133 to 143)
Lane discipline
133
If you need to change lane, first use your mirrors and if necessary take a quick sideways glance to make sure you will not force another road user to change course or speed. When it is safe to do so, signal to indicate your intentions to other road users and when clear, move over.
If you need to change lane, first use your mirrors and if necessary take a quick sideways glance to make sure you will not force another road user to change course or speed.www.highwaycodeuk.co.uk
Exactly this! Nice to see it confirmed.Roadcraft (the Police drivers manual which tends to be used by the IAM etc) used to say "Give a signal whenever it could benefit other road users" so you should asses whether someone would benefit from seeing that signal
[....] "Give a signal whenever it could benefit other road users" [...]
It's easier to use the indicator always than to have an accurate model of what other drivers want from you. When I see someone on a motorway drift left without indicating (like @kinboshi) it's unusual enough to become the focus of my attention. I may need to judge if they're doing it because they're changing lanes or because they're distracted and I should stay away from them.Exactly this! Nice to see it confirmed.
I only indicate if to not do so would inconvenience another driver. Obviously this requires you to be aware of the road and other cars at all times. So many drivers seem to be on autopilot not even processing whatโs going on in front of them let alone behind. Indicators apparently give them the right to pull out immediately whatever the situation is around them. Itโs a signal of intention not action!
Personally speaking and because of this I do turn off the lane assist as I hate the wheel tugging.
If I 'drift' left in front of you, and it's something that you might not necessarily expect, then I'll indicate (and also have a look first). If I indicate to overtake someone in the left lane, go past them, and then pull in a good distance ahead of them - I don't automatically indicate - especially if it's near a junction, etc., and the signal could be misinterpreted. If I've been in another lane for a long period, and am about to move into the first lane in front of a car (maybe before an exit), then I would usually indicate. But again, it's usually done for the benefit of other drivers (and myself), rather than an automatic action.It's easier to use the indicator always than to have an accurate model of what other drivers want from you. When I see someone on a motorway drift left without indicating (like @kinboshi) it's unusual enough to become the focus of my attention. I may need to judge if they're doing it because they're changing lanes or because they're distracted and I should stay away from them.
My point being, 'whenever it could benefit other road users' is very very broad.
This.The way I was taught (by an ex-police driver) was that you should indicate to users that you are about to do something they may not necessarily expect.
This.So, you would always indicate before, say, pulling out from lane one to lane two to pass a truck, but if lane one is completely empty in front of the truck then the truck driver should expect you to pull in anyway so indication is not necessary. All you are doing is returning to the default road position (MLMs be damned!)
This.If you were pulling back in front of the truck and there is traffic in the inside lane ahead, then you should indicate as this (literally) signals your intention. 10 seconds is my rule-of-thumb guide to determine whether I'll pull back in or not; if I'd spend less than 10 seconds before having to pull out again then I'll stay in lane two/three/whatever.
This!This was the way I always drove in the UK, but driving on the continent (where rules vary) plus the advent of lane-keeping systems as being discussed here, mean I always indicate both ways nowadays.
