GR Yaris 621 Run in
BomberHarris
Peterborough
Quick question for you good people please. When did you start to open the power up? Dealer said to me keep it no more than 3000 revs to run in. Seems fair enough but are you straight into the good zone after that? Are you easing power in just before or are you still cautious playing with the power up to 1000 miles?
Mines not the daily. Run a Golf TDI estate for that. GR has 400 on the clock now not a lot in 6 weeks admitted but it’s getting closer to that magic number!
Get in. Warm it up. Drive it.
Take it a bit easy for the first 621 miles (or any other arbitrary number of your choice ;) ) if you must, but certainly don’t hold constant throttle for long periods, and don’t be afraid to go over a particular engine speed like the (misinformed) dealer said.
That’s much more likely to cause problems than caning it from day one imvho
Yeah, from what I've read and been told - there's no rev limit (other than the red line). Make sure you warm up the engine before giving it the beans (that's not just for the first 1k km), and follow the guidance in the manual:
It’s in the manual ^^^.
There’s no rev limit. Just avoid constant engine speed. So if you’re on the motorway or long straight roads, change up and down to vary engine speed. That’s it.
Warm it up, smash through that megametre and then rip up some tarmac. That’s what it was built for.
I failed miserably on my planned run in. Complete failure. The car was to willing and fun for me to comply with my own plan. It was like stopping mid coitus. My brain did not have the correct nerve links to manage, I got locked in! I’ve driven it with joy from km 126 or something. I must admit I’m kinda disappointed with myself and scared that I have cucked something up, but hopefully not🖖
The first 20 miles will pretty much ensure the engine is run in. The rest is for the drivetrain really. As others have said, just follow the manual. I tended to give a good amount of throttle in say 2nd gear, then lift and let it slow down on the engine. However, probably most of what can be done already has by the time you receive the car anyway. I just gradually increased the rev limit and as per the manual, no cruise control and varying the revs.
Just be sensible, follow the manual if you can remember and hold yourself back, but if you can't just remember - 10 year warranty! I doubt they'd be able to prove your engine failed 9 years on at 86,000 miles because you didn't run it in properly. And as Lauren says, it'll have been ragged round the docks by the stevedores like a proper rally car for the most important miles before you ever see it. Relax, it's a Toyota :)
Excellent advise by all. Hands up I’ve not completely held exactly to this supposed 3k rev limit (advised by dealer) on every ride but tried to resist the temptation as a rule. Rules were made to be broken and temptation beckons strong! We give it some this weekend after a nice warm up!
put it this way the demo car i tested certainly wasnt run-in / treated gently :ROFLMAO:
i think of all the new cars i have had i havent really run-in any of them....and all were great and no oil was consumed in the process 🧐
3K rpm is way too low to be able to keep to and definitely not the way to run an engine in. Even with my old GT86, was advised no more than 4000 rpm for the first 1000miles, but I didn't keep to that, though I didn't rag it either. Engine lasted 150,000miles. Really you don't want to run an engine in too gently, but really once you've done 20 miles or it's done anyway. Its all about sealing the rings. In my first 20 miles I overtook a duffer and accidentally hit 5500rpm, which I absolutely didn't mean to. Just took me by surprise how quick it revved!
3K limit for 1000km's is just silly. Babying it for 1000km's under 3K will not run in the engine properly. Part of that run in period is for the brakes and drivetrain. Just drive normally, but don't do anything extreme, just like the manual states. After a certain time (could be 20 minutes) proper break in/seating the rings doesn't even happen anymore, it's too late. Ofcourse there's different engine technolgy, old, new, cylinder coatings, low friction rings ect. Not going to get into that, but it's safe to say just don't do anything extreme, bang on the limiter, lugging, idling ect.
I'm firmly of the opinion that most of the run-in periods recommended are a bit more to do with acclimating the driver to the car than anything mechanical! Well, other than getting everything out of the initial down-slope of the bathtub shaped failure curve...
The car has a built-in boost limit cold so it cannot been 'run-in' at the docks....
Follow manual which for me (and tech explanations I won't repeat here) means:
Warm up
Vary revs
Short bursts of WOT (1-2s)
= you can already enjoy the car
In case of doubt, the above doesn't mean banging it on the rev limiter at every opportunity either ;)
To find answers for myself Iwas reading a lot, talking some engineers and wrote Toyota technical department. After some redirections I got an answer and put this together withe what I know and I was told bei experienced people who work with engine and in development.
My question in short:
What is the best breaking in procedure for the engine and why it's written in the manual as it is.
My short summary and answer:
1) The technical procedure in the manual is very simplified because the majority has to understand and comply to the description. (Statement of toyota)
2) these recommendations are more of a minimum not optimum for breaking in. It's a compromise between user friendliness, durability und engine performance. ( yes, you can run in for max performance or max durability)
3) engines are far less depending on propper engine breaking in then in times of cast iron blocks and bigger manufacturing tolerances.
4) Yes there is a difference but it's not so big anymore.
5) to soft breaking in produces an engine that is durable but a bit lethargic on power delivery.
6) to hard breaking in reduces durability, increasing wear and tear, increasing oil consumption and burning and reduces compression and therefore power.
7) performance engine breaking in procedure;
- Warm up engine. With varying 0 -25% throttle.
- Burst to about 50% throttle, hold rpm for several seconds, use engine breaking to slow down.
- Repeat several times.
- Repeat this for every gear. (If possible, high gear means high speed after all)
- Burst to about 75% throttle, hold for several seconds, use engine breaking to slow down.
- Burst to about 100% throttle, hold for several seconds, use engine breaking to slow down.
- change engine, diff and gearbox oil.
For street cars you can go on with:
- avoid constant engine speed for about 500 km
- increase max rpm slowly to redline over the 500 km.
8) the first few hours and kilometers are most important. After that it starts to fall off rapidly.
So that's what I do, and what I recommend, when I am asked. If someone wants to do it differently or has an other opinion, I am happily listening to their reasons and put this into my perspective. I may be wrong after all, but the above procedure is well known, I saw it proofed to work great in the past and after talking to some engineers it makes mechanical sense.
BUT things change. Engines change. So it's also a topic in change. But I have the feeling for some this is a more a religious thing than rational engineering. I would like to see a proper study with some same engines with different breaking in methods. But that would only apply to that engine than. So I guess we will never really see a real rational approach to this topic. It's to complicated after all. Do what makes most sense to you. Build you opinion on best knowledge and facts. Respect other opinions. Be open minded to learn new and change your opinion.
At the end it's a tiny little bit of a car and even less of your life. So don't over exaggerat it. That's what I am telling myself. To more ore less success. 😆
Good one @GRunt .
What you described there is an engine dyno break in. I traffic there isn't such control. In practice it ends up more or less as in my previous post, the warm up (hopefully), using all gears (vary speed! ) and part throttle is usually covered in normal driving, the short burst of 100% throttle usually are missing when people are being too careful in breaking in. Hence why I mentioned it ;)
At the docks the cars will (should) be driven slowly. Used to load cars from Nissan Sunderland onto ships, we'd get a bollocking for exceeding speed limits.
In the factory every engine will be run up.
Oops, hit enter too soon.
@GRunt explains it perfectly. We use similar methods to run in ship's engines after major overhaul - warm it up, run to a certain load, low load for a time, up to next load level etc...
They make a little tour on a test track to see if everything works, but no real running in procedure as such...
Actually the engine of the new NSX from Honda is undergoing a completely break in in the factory on a test bench. But that's the only example i know though. Guess this exclusive for, uhm exclusive cars.
