GRunt
I mean this is the oil cooler... and doesn't it use the engine coolant? What actual effect would you get from increasing it slightly?
You can increase cooling capacity quite some up to the point the coolant itself gets too hot. So it's a balance. Maybe the coolant get some better cooling too, it's a bigger deeper nose after all...I mean this is the oil cooler... and doesn't it use the engine coolant? What actual effect would you get from increasing it slightly?
Well doneI mean I stuck a hose pointing at my oil cooler and it made a much bigger difference than I ever imagined. Maybe they see my build thread![]()
Silly though that if you look some Group B rally cars and Huyndai Rally1 car it has single exist exhaust pushing close to 400hp, with Group B closer to 500hp. so not sure if three exhausts are REALLY needed, or if it is more of an Type-R - match thingy..Some more information:
" Increased boost pressure isn't the only source of the power increase, too. The central tailpipe on the GR Corolla helps reduce back pressure, further increasing horsepower."
Spot on.It is all about marketing.
Imagine they said "we gave the Corolla just a little more boost to compensate for the weight". How many Yaris owners would feel bad and wanted that too?
Instead it is the miraculous third exhaust pipe.
