cdruk
Absorbed member
- Aug 23, 2022
- 48
- 77
Thanks!Toyotatech.eu is your friend. You will have to create an account and pay for access.
Or download full parts list PDF from GR ZOO.
According to the info from a GRY FL (MK2) Owner are the seat mounting points in the bodywork a lower designed now.OK, no surprising news here: dealer claims that the post-facelift mounting kit is not available by itself, only as part of an entire new seat. Which costs ~1800 eur. As for compatibility, he said the only way of finding out for sure is to actually order the whole thing. Shame.
I'm still looking for ways to lower my seat on my new GRY MK2.
Is the seat mounted lower in the car and thus can I use a seat lowering kit which fits the original seat?
In the past I needed to have a fixed seating position with a Recaro Pole Position ABE however I'm at an age where I would like to retain the original seat.
Anyone who can tell me something from these pictures I took at the Nurburgring earlier this year?
www.swmotorsports.uk
importracing.de
I have decided to buy a lowering kit for both driver & passenger side.
I am trying to decide one of the following...
Toyota Yaris GR OEM Factory Seat & Slider Lowering Kit - SW Motorsports
Toyota Yaris GR - Super low Seat Base Mount. Designed & manufactured to perfectly fit the car’s existing mounting points. Multiple colours & installation available. Shop now. gr yaris lower seat, gr yaris seat height, gr yaris seat lowering, gr yaris seat lowering kit, gr yaris seat mount, gr...www.swmotorsports.uk
Importracing GR-Yaris seat lowering OEM driver seat (LHD) - Importracing
Seat bracket for lowering the original driver's seat by approx. 33mm. Optimized seating position for tall riders Standard seat adjustment remains of course Optimal fit due to CNC-manufactured components for easy conversion. Working time approx. 1 hr for the conversion Seat consoles supplied in...importracing.de
Seat lowering Toyota Yaris GR | GP Elite
gp-elite.com
Could you suggest one of the above kits?
Is there any stability issues?
I know that all of them need to cut plastic parts...and I am not very happy about this...
Especially gp-elite kit need to cut 10 millimetres of plastic trim on the side plastic trim of the seat......
Thanks!
I can't say anything about any of these kits, because I haven't tried them, but I can say that the plastic part you have to cut under the seat (excluding the gp-elite) is completely invisible, it is under the seat, and will not be visible even if you revert to OEM.
I had the SWM mounted on the GR1, the truth is that it looked very solid and well built. On the other hand, it was very heavy.I have decided to buy a lowering kit for both driver & passenger side.
gp-elite.com
Thanks!
I also had a lowering kit both sides that I decided to remove after a while. In my case I couldn't live with the amount of vibration/movement I could see travelling up the passenger seat back when it was unoccupied, and after removing the passenger side I couldn't live with how much higher it then was compared to the drivers side!Reversed my Importracing seat lowering yesterday. From the get-go I felt I teny tiny bit of free play in the seat. The added layers between me and the chassis resulted in my seat being a bit less rigid. I accepted it due to the more comfortable position.
Now, after 20k KM, the seat was starting to squeak at bit, so I decided to reverse it. And what a decision.
No squeaking and I gained about 20 hp from being directly connected to the chassis and getting the kick from the engine and gearshift directly in my spine, not through 2 centimeters of «seatlag». I’ll live with my beanie rubbing against the roof in winter.
Lastly: no cutting or stuff like that so it’s fully reversible.
Oh wow really? Was literally just about to order a SWM slider / tilt kit but really don’t want any vibrations as the car is buzzy enough as it itI also had a lowering kit both sides that I decided to remove after a while. In my case I couldn't live with the amount of vibration/movement I could see travelling up the passenger seat back when it was unoccupied, and after removing the passenger side I couldn't live with how much higher it then was compared to the drivers side!
It wasn't easy readjusting to the standard seat height again, but you get used to it.
The driver's side was fine tbf, as I was always sat in it - never noticed any movement and lower seating position was great.Oh wow really? Was literally just about to order a SWM slider / tilt kit but really don’t want any vibrations as the car is buzzy enough as it it
So the stripes on the long pieces are there to hold the mounting bolts in place?.I'm using my DIY seat-lowering solution. Yes I know, it's not engineered by a actual engineer, not welded by a professional welder and certified only by my common sense. But I'll take my chances.
It lowers the seat by approximately 30mm, is very sturdy, and frees me from the existential dilemma: "Should I go one click forward or back?"
Long pieces are made of 50x5mm steel. Steel angles, 20x20x3mm, form hollow strengthening ribs for the long pieces, serving solely as reinforcement. The seat mounting studs are countersunk M8 10.9-grade bolts, welded from beneath. The front ones are covered by the angle iron, while the rear ones are visible positioned around the rear mounting hole, which is also countersunk to allow the rear seat bracket to rest over it. Washers around the mounting holes are used to raise the "rails" above the carpet, ensuring a steel-to-steel contact with the car body rather than a steel-to-carpet-to-steel connection.So the stripes on the long pieces are there to hold the mounting bolts in place?.
Is one piece angle?. Bit hard to tell being all black.
