Oh Boy, right so today I got the decoder box, and on we want on installing it, it's CAN right, should it matter where we connect to it ?
So we went right to the obd port, I mean its right next to the switch and everything, easy right ?
Wrong, we hooked it all up, and the Lazer CANM8 box blinks red, no ledbar turning on.
Then we started thinking do we really have to dismantle the whole bloody dash to get the speedo out according to the instructions of CANM8 of old 2020 yaris model, ain't no easy task on the new model, full disassembly of the dash. Luckily our electrician and diagnostician ain't stupid, even though a young lad, as we have access to all Toyota technical info, he started to look where does the wiring loom go from the instrument cluster.
Lo and behold, an easily accessible place on the other side, under the glovebox, a small two wire extension for us, luckily there is space between the two sides underneath that you can even get an arm through, stripping the connection on the cable, hooking all up and Eureka !
The white little box is not blinking anymore and we got ledbar on the original stalk working in tandem. Now just to hook it all up decently and hide all the wires and isolate them, but we got it working quickly and without disassembling most of the car. For anyone's future ledbar needs on mk2, just guide them to this post.
The hookup location is called Gateway ECU, ON LHD cars under glovebox.
Pin 30 Red Can high, pin 29 white can low
Well here we go.
Now we wait for exhaust and mudflaps.
And in a month or so, the winter wheels will get ordered.
