GR Yaris (Gen 2) Armijs GR YARIS MK2
Are you planning to go on gravel roads? Is the plastic cover not good enough?
Ice blocks in the middle of highway in winter main fear of mine, fallen off from heavy trucks, basically chunks of snow and ice from whel arches e.t.c., i dont want to risk to destroy a 400 eur piece of plastic, if i can put on a 140 EUR steel sheet :D In summer i can put back on the plastic one, for better cooling e.t.c. In Winter i rather be safe.
The plastic one is basically almost made out of paper, if something harder and taller goes under, the plastic piece wont do anything at all to protect the oil pan e.t.c.
Makes sense. Now I'm considering the same thing for mine... 😁
Sorry for my ignorance, but what is this and does / would it make sense in countries with better fuel quality?
I was actually very surprised that i did not see this in my regions maintenance plan at any mileage, meanwhile a regular Corolla or RAV-4 hybrid has it every 30 or 45 thousand in the maintenance sheet, in the manual it says that in specific countries this has to be used every 10 000, like Albania, Romania, Moldova e.t.c So it really is not doing anything bad, why it is not in the maintenance plan in the Baltics, at least it was not not that long ago, puzzles me and i am just adding it myself.
It basically flushes the fuel system and helps eliminate carbon deposits and improves the working of fuel system in its entirety .
In countries where 100 fuel is available etc, probably not, although Carbon build up more or less is inevitable anyway, you could just use it less than i will, it wont do any harm IMO anyway for the fuel system to stay in TIPTOP shape.
Got the skid plate today, fitted it ASAP, was for a Yaris Cross supposedly, fitment was alright, side fittings were a little bent during transport but they were not necessary for the GR at all, just bent them back.
For the money, knowing this will be only used in the winter, 140 EUR, more than good enough. Using hidraulic lift, bent the middle section a little bit closer to the car so the clearance stays more or less the same as it was.
I wonder if the ducted GR undertray will be a more affordable upgrade to the mk1 crowd compared to the GRMN crowd?
I can see one of the reasons you’ve gone for the metal undertray over winter!
That is one reason, yes, well that is MSRP, price for me is about -40 % of that more or less, but yeah, i rather have something sturdy for the ice chunks on the highway from lorries, once spring comes, OEM lighter pan with cooling goes back.
@Armijs when you get a chance, can you tell us the part number for your GR Undertray
Oh Boy, right so today I got the decoder box, and on we want on installing it, it's CAN right, should it matter where we connect to it ?
So we went right to the obd port, I mean its right next to the switch and everything, easy right ?
Wrong, we hooked it all up, and the Lazer CANM8 box blinks red, no ledbar turning on.
Then we started thinking do we really have to dismantle the whole bloody dash to get the speedo out according to the instructions of CANM8 of old 2020 yaris model, ain't no easy task on the new model, full disassembly of the dash. Luckily our electrician and diagnostician ain't stupid, even though a young lad, as we have access to all Toyota technical info, he started to look where does the wiring loom go from the instrument cluster.
Lo and behold, an easily accessible place on the other side, under the glovebox, a small two wire extension for us, luckily there is space between the two sides underneath that you can even get an arm through, stripping the connection on the cable, hooking all up and Eureka !
The white little box is not blinking anymore and we got ledbar on the original stalk working in tandem. Now just to hook it all up decently and hide all the wires and isolate them, but we got it working quickly and without disassembling most of the car. For anyone's future ledbar needs on mk2, just guide them to this post.
The hookup location is called Gateway ECU, ON LHD cars under glovebox.
Pin 30 Red Can high, pin 29 white can low
Well here we go.
Now we wait for exhaust and mudflaps.
And in a month or so, the winter wheels will get ordered.
Damn. Too bad I didn't follow your thread closely or I could have tipped you to get XBB. So much easier, wireless. Well it worked on the mk1, not sure there is a recipe for the mk2 yet in case canbus signals differ - so for you this was maybe the right solution...
(y) Top man, thankyou
Slight correction, 51410-52200 is the whole pan, 51443-52130 is the middle bit, maybe it is orderable separately. And fits any pan if the cutout form is the same for all.
EDIT:
But when trying to look up pricing for only the middle bit, although it has a separate part number, it is not findable or orderable it looks like, so you have to order the whole pan as far as i can tell.
Yesterday when i took the measurements of the middle section of the exhaust for the custom exhaust guys, i also took pics of the OEM "skid plate".
Looks like mounting places are still the ame as they were mostly on the regular Yaris from 2020, might be the cheapest option to get something quick.
We ordered for our Land Cruiser 125 from there as well after i found about this site from another member on here. Price is excellent for what you get imo.
And free shipping !
Over all now, just waiting for two of the guys i contacted to get back to me about approximate pricing on the custom made GPF delete, and still waiting for snow and a complete exhaust, the yesterday found Polish company might just be it really. Thanks @Euge for pointing it out !
Exhaust youtube video
@Armijs I couldn't find the GR Yaris on the site. Which model did you get for the GR Yaris MK2? Would order one for me as well.
It's the regular Yaris or Yaris cross skidplate, with easy adjustments fits gr without issues
